So it turns out I'm actually leaving on August 9th instead of the originally planned August 8th. That means I'll be attending this meet. Whoo! Can't wait for this event.
Thinking of coming to this meet with the HE90 though. I'm having some problems with my ES-1, thinking it is the tubes. Hopefully I can get it straightened out.
EDIT
The left channel is all messed up. I thought maybe it was a tube problem. However, I have changed tons of tubes lately, and no matter what tubes are in, the left channel is quiet and distorted. Almost as if the left side is not pushing and pulling like a stat shoud
So im thinking its definetly the amp?
I just read the millions of pages of Singlepower crazyness. I had been on a year long leave from headfi due to school. I was thinking of sending the ES-1 back to Mikhail, but I dont think so now.
I've got a HE90 that I cant listen to, and im unsure what to do now, hah.
Anyone brining an amp that I can hook the HE90 upto?
Cheers strung. my ES-1 has HE90 jack.. you could plug into... My tube selection is pretty much setup for O2's... but you are more than welcome to share the amp... if no others are available....
(I did a lot of research and learning and worked on my own ES-1, but I would probably not advise it, lots of high voltage stuff in there. I would probably find a friend of a friend that has experience to take a look at it first before sending it back to the black hole of SP)....
The PPAS is up and running, we'll have one happy winner there. A little background noise with super-sensitive IEMs (well, it is based off PPA design, not really an IEM amp), but no noise with normal headphones until you get to "way too loud to listen to" levels without music playing.
I would be happy to run the raffle; nothing fancy, will just drop by a store to grab ticket numbers and draw from a hat.
