'noodle' dac (ebay special)
Aug 25, 2008 at 4:12 PM Post #16 of 180
the chap that did the mods originally suggesta resistor is needed to load the dac.
I just dont see why this is needed, inline with that you will have 50k, what difference a 68k resistor makes i do not know.
Aug 25, 2008 at 7:20 PM Post #18 of 180
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif
Is your fire insurance up to date?
Please explain....
Aug 26, 2008 at 11:38 AM Post #20 of 180
I'd be afraid the box would catch fire. Maybe I'm wrong, just looks scary.
It's going in a propper case. It was only connected up in the box for a quick test!
I was worried that you were suggesting that the capacitor mods would make it liable to catch fire!
Aug 26, 2008 at 5:25 PM Post #21 of 180
for all those worried about my cardboard box (sorry about the crappy phone pics) :
its now house in the top unit.
Aug 27, 2008 at 7:27 AM Post #23 of 180
re,oved the signal electrolytics, replaced with obbilgato film. changed the opamp to a opa2107. sounds lovely.
Aug 27, 2008 at 8:41 AM Post #24 of 180
Do you have a picture of your mods?
Aug 27, 2008 at 1:35 PM Post #25 of 180
same as the guide picture i showed you.
except i have obbligatos in the signal chain. I am confused by the apparant need for the resistors. I can only assume its for when nothing is connected, otherwise putting a 68r resistor in line with a pot (50k!) cant make any difference. Eitherway, i didnt put the resistor in line and havent experienced any issues yet.
Aug 27, 2008 at 4:36 PM Post #26 of 180
Think one second about it. What happens if you short the output to ground, with and without the resistors ?
Aug 27, 2008 at 5:21 PM Post #27 of 180
cap will dump resisdual charge back into g.
why would i short the input though? if its just left pulgged into my amp.
Aug 27, 2008 at 6:47 PM Post #28 of 180
tss, tss, you have to think like a DAC builder: sooner or later, one of your customer will short the output, while the dac is playing. The opamp will try to push 2Vrms into a short. It could fry and the customer won't be happy. If you put something like a 100 to 1k resistor in line with the output, the opamp will survive easily and the sound quality won't suffer at all. No need for very low output impedance here.
As a guess, the resistors protecting the output were R28 and R29. On the pic you show, the modder removed those (among others). He thus had to put some new resistors to protect the output against a short.
Aug 27, 2008 at 7:19 PM Post #29 of 180
From the schematic supplied with the DAC, R28 is a 100K resistor connecting the LOUT with ground whilst R29 is a 100K resistor connecting ROUT with ground.
I'm currently modding my DAC and have only removed the 6 electrolytic capacitors (replaced with wire links) and added 0.47uF film caps to the outputs - I haven't touched R28 and R29 - so do I need the extra resistors?
Aug 27, 2008 at 7:51 PM Post #30 of 180
Bad guess thus
R28 and R29 are thus simple pulldown resistors, to avoid "pops".
Still, all the rest stays true. You really need a resistor in serie with the output to be safe. There might be some on the pcb already ?
