donkey stains
Hello All
First off its great to be part of a helpful and insightful community with similar interests.
This is my first posting here so apology's in advance if it sounds like I am unsure of what I am talking about. I am looking to purchase a portable DAP for playing my FLAC collection but mostly streaming from Spotify / Tidal. I also want to purchase over ear open back headphones for listening while at home.
I currently own a Fiio X5 2nd gen, Fiio Mont Blac amp and Shure 535 IEMs.
Spending this amount of money is a huge deal to me, so I really want to make sure that the items I have listed below will be compatible and the best bang for my buck. From my research and my budget I have my eyes on the following products:
DAP : either the Hiby R6 or the Fiio x5 3rd gen
Headphones : either shure 1840 or the Sennheiser HD 660s
I have the following questions that I am unable to resolve myself and would really appriciate some answers before I go throwing my credit card at something that may not be suited.
1. From the above 4 products is there anything that stands out as non compatible (example I understand the H6 has a very high output impeadence - would this effect my se535, se1840 or the senn hd660s?)
2. Using the above 4 potential products as a my budget guide, are there other products that I should look into that are in my price bracket ?
3. Would it also be worth upgrading my Fiio Mont Blanc amp ? if so, breiefly why ?
4. With regards to the headphones, I thought I may put a little bit of info as to what I like / dislike about my se535s to help you understand how my ears are tuned.
likes : Clarity, decent staging & not an over the top amount of bass
dislike : the vocals do not match the impact the instruments have on me, the sound can be clinical / nuetral
5. Will both headphones mentioned above work with balanced cables ? Would it be worth investing in balanced cables ?
6. Complete curve ball here but if I was to opt for a DAC to use with my LG v30 phone / random laptop would I end up with a better sound quality then the 2 above mentioned DAPs? (I have been looking at the iFi audio iDSD black label micro DSD DA convertor as its roughly the same price as the Hiby r6)
Thank you in advance for the help and advice
Cheers
Donkey
Cheers
Donkey
