Originally Posted by jsaliga /img/forum/go_quote.gif
I have driven my car over 240,000 miles with the "Check Engine" light on. No kidding.
I've done the same and religiously ignore the idiot lights.
Actually, cars are programmed to turn those on whether there's a problem or not. Mine turns on every 5,000 miles. I know how to reset it, so I do.
Car manufacturers do this for their dealers. If you look at how car dealerships are set up, they're designed to break even on car sales. All profit is designed to come from service and part sales.
This is why you're showered with fliers, "free" oil changes, etc., etc., etc., ad nauseum from the place you bought your car. If you ever go to a dealership for an air filter, they will put you on their mailing list and inundate you.
Also, a car usually gives you a bunch of hints when something is about to go wrong. If you know what to look for, you can almost always head them off. It goes without saying that you should do the routine maintenance and not drive like a moron. That's how I've treated several cars over the past 20 years and a good 400,000 miles. No catastrophic failures, despite any number of check engine lights being on.
As for the OP, I'd start with the fuses and pick up the Haynes manual (or shop manual) for your car. It'll have checklists for each of those problems you can follow. I'd recommend learning to work on your car instead of a shop that will just try to sell you stuff you don't need. And given that labor is at least $40 an hour these days, you're better off with a set of wrenches.
