Jun 15, 2009 at 2:55 PM Post #62 of 154
Originally Posted by toughnut /img/forum/go_quote.gif
Summary
S630F: Smaller soundstage, quite raw/energetic sound due to boosted treble, mid quite forward, bass sound less full
5800XM: Bigger soundstage and fuller bass. Treble more mellow while mid not that forward. Background hiss less than S630F (not really noticeable on S630F unless u max'ed the volume)
This only applied for CK100. I prefer CK100 on 5800 but for my other IEM/headphone, S630F is better. More bout synergy than SQ. Others sound dull on 5800.
P.S: 5800 music player is very crappy, functionality wise.
-Thanks a lot Toughnut this was very helpful. As a current owner of the s738 I'm in agreement with your summary. That synergy really must be a good one! thaks again
Cheers
Jun 16, 2009 at 9:25 AM Post #63 of 154
Originally Posted by nvkid909 /img/forum/go_quote.gif
overall quite like my 5800 sound quality, bass is very good .... i do think it compares better to my W890i ...
Could you give more detail on this comparison? 5800 vs 890i
Jun 18, 2009 at 6:20 PM Post #64 of 154
I have the 5800. Functionality is poor as said. I am using it purely as a music player. I have added a Graham Slee Voyager amp, as the volume on the phone is not quite loud enough for me even at full volume, which then introduced distortion. I am using Senny CX300 in ears. SQ is almost very good. The top end lets it down big time IMHO.
Jun 25, 2009 at 5:59 AM Post #65 of 154
For those using 5800 or any Nseries/ExpressMusic phone, try using "Lineout" instead of "Headphone". I was floored by 5800 "Lineout". Huge power even at min volume, sound a lot better even at equivalent "Headphone" SPL. Everything just sound fuller.
I always ignored other options till today since i accidentally touched "Lineout", nearly caused me to lose my hearing
Jun 25, 2009 at 10:27 AM Post #66 of 154
Blimey! That's better! Thanks for that, I never noticed the option.
Jun 26, 2009 at 5:11 PM Post #68 of 154
what kind of battery times are u guys pulling off with the 5800 and music listening, with some regular phone usage included (few calls per day, maybe some wlan..). Anyone using Hd25-1 with thise phone, good match?
Jun 26, 2009 at 5:36 PM Post #70 of 154
well can u please tell where from the "lineout" signal is to be extracted other than the 3.5mm headphone out? I have the N91 8gb.
Jun 27, 2009 at 5:03 AM Post #71 of 154
It's still via the same 3.5mm output but under different profile when u insert the jack. On 5800, there's 4 options = Headphone, Lineout, Headset and Music Stand.
Regarding battery life, i can easily keep it alive for 50 hours. Couple of sms, few minutes of call, 5-6 hours of music, 2-3 hours of wifi browsing.
Jun 27, 2009 at 12:58 PM Post #73 of 154
battery time is not great if you use it constantly then do periodic scans for wifi or use 3g aswell. i get a day out of it for 'normal' usage (ie: ignore those people telling you not to use this & that feature). just charge it every two days, & if you're out more than a day, maybe one of those cheapo AA or solar chargers will keep you worry free.
i'm using HD25-1, denon ahc551 & even HD595. i think this phone has an amp chip better suited to cans whereas sony walkman phones are made to do earphones. this phone has a bigger sound than sony ericssons for sure.
i can't really tell the diff between LO & HO (or the other two settings) with my cans but then i am getting a pretty big sound from HO, maybe it's got something to do with the capability of the cans themselves. sound from my c551s is, ok.
Jul 21, 2009 at 7:37 AM Post #74 of 154
Originally Posted by Newtype2011 /img/forum/go_quote.gif
If I ever get a 5800, I'll be sure to let you know. Nokia N91 produced more hiss than I would have liked, so I don't think it will be difficult for the 5800 to put it down -
Can't be hard to beat the N91. My N91 hisses like mad with my CX300s (admittedly low impedance). I almost actually can't listen to anything except rock.
