xluben
- Jan 4, 2005
No active noise cancelling devices will do a good job blocking out voices. They are designed to help stop constant, repeated noise (like jet engines, fans, etc). I think the QC2's may work well for this situations, but are fairly costly if not being used for music. Also, as mentioned before, active noice cancellation circuits will cut much less noise than passive solutions (earplugs).
Originally Posted by Mercuttio I've got to disagree with you there... I found the Q2C to be quite overrated even as a noise canceller. It blocks out lower frequency humming sounds, but has absolutely no insolation against anything in a higher frequency, like voices. |
