No sound from left driver?
Feb 21, 2015 at 9:49 AM Post #16 of 17
Anyone know how i open up the aune t1? There's screws on the bottom but there covered by clear plastic that allows the base to sit a few mm off the surface but can't seem to remove them?
Feb 21, 2015 at 1:47 PM Post #17 of 17
Hi guys. Got it open earlier and fixed the problem which was a loose connection. Putting the thing back together was the bloody hard part ha but all is well now :)
One small annoyance tho. The amp is also connected to the computer and whenever it's turned on it automatically wakes the computer which is fine if iam using the computer but when it's set to line out and not usb, I'd rather it didn't wake the computer! Is there a fix apart from the obvious (unplug the USB)??
