So basically bridging = having one or more amplifier per channel that are working in sync. bridging =/= 'balanced" as the term that professional non-headphone uses. so what are the technical benefits of bridging if it is not offering the common mode noise rejection benefit?
Ok, with a typical single ended amp, you have just a single amplifier for each left and right channel. At the input, one terminal is the input and the other terminal is ground. At the output, one terminal is the output and the other terminal is ground.
With bridging, you take two identical single amplifiers and bridge them together. At the input, one terminal is the input to one of the single ended amplifiers and the other terminal is the input to the other. At the output, one terminal is the output of of one of the single ended amplifiers and the other terminal is the output of the other.
The load is tied across these two output terminals and effectively "bridges" the two amplifiers together, which is where the term "bridging" comes from.
Typically, the input to one of the two single ended amps is fed a normal signal. The input of the other amplifier is fed an identical signal, but of the opposite polarity. In other words, if the normal signal is at say +2 volts, then the other signal will be at -2 volts. So now the differential voltage across the two output terminals will be (+2) - (-2), or +4 volts. Twice what it would be if just using one single ended amplifier.
The "benefit" is that if your power supply voltage is such that the single ended amp can only swing
x volts, with bridging, you can use the same power supply voltages but achieve 2
x volts.
Bridging was commonly used for car audio back in the day where you only have 12 volts to work with. So bridging, combined with using lower impedance 4 ohm loudspeakers let you wring as much power as possible from the limited power supply voltage available.
Of course now car audio uses switching power supplies (DC to DC converters) to achieve whatever power supply voltages they want.
But for AC powered home amplifiers, you can choose whatever power supply voltage you want, so bridging is of dubious value. And even battery powered devices can take advantage of DC to DC converters to achieve higher voltages as well.
'balanced' via the professional definition = a balanced interface at the input. what is a differential input mean exactly? I was under the impression that RCA input connectors are single-ended, so does that mean that XLR inputs would be differential? Or is it relating to something else completely?
Ok, first of all, "balanced" refers to the impedance of each line with respect to ground. In a balanced interface, those impedances are the same. With a single ended interface, one of those lines
is ground, so by definition, is inherently
unbalanced.
A differential amplifier only amplifies the difference it sees at its two terminals. Even single ended amplifiers typically have differential inputs, but for common mode rejection you need balanced impedances between each line and ground. This is because interference noise typically impinges equally on both lines, but without impedance balance, that noise won't appear equal on both lines. In other words, the voltage produced by the interference won't be common mode. No common mode voltage, no common mode noise rejection.
Also, if being "balanced for common mode noise rejection" only relies on the input, is it possible to have a single-ended output with a differential input that is 'balanced'?
I didn't say common mode rejection only relies on the input. I said where common mode rejection actually
occurs is at the input. The outputs need to be balanced as well in order to keep the noise common mode.
Sorry if these questions are silly or obvious or just incorrect. I don't think I understand the topic as well as I would like, and I would appreciate some clarification. Or at least perhaps a link where I can do some personal reading & learning. thanks!
Wikipedia has a pretty good treatment of the subject.
http://en.m.wikipedia.org/wiki/Balanced_line
se
