I've had the Jot1&2, Asgard 1-3 & Lyr1/2 and Lyr+. Albeit the least amount of time with the Lyr+. Jot 1 has a wall of sound approach but it really rocked with HD6. Jot2 was like a bowl, still liked it. Has it's weaknesses with anything airy. Asgard 1 was like a warm blanket with a diffuse stage. A2 cleaned this up quite a bit but was a little grainy/hazed, I still liked it especially with planars. Lyr+ is not the most detailed and I feel like the technical performance would have been better if they focused on either ss or tube. Tube was still better, high failure rate held it back. PM is my favorite as it sounds more resolving, detailed and genre capable/friendly than any of them. Lyr+ wins out on overall stage size, Jot wins out on grunty slam, but each amp trades more off in comparison to the PM.
In a twist to the testing plot, I'd like to see how the Pietus would compare to the Midgard, with Midgard in Balance mode compared to Pietus which is single ended. I spent some time yesterday comparing the Midgard in SE vs Balance mode and the latter was much better. That being said, I would assume the Pietus would be much better than Midgard if both used in SE mode. The plot thickens. Thank you.
Oof, this with the MMB DAC card sounds like the ultimate all-in-one. Probably better than Asgard 3. But $750...I know that's not bad for what you're getting but I don't think I can spend that right now. I know these Nitsch x Schiit products tend to be limited edition, and I don't want to miss out...
I'm really tempted to buy this amp only and add the phono card so I can listen to vinyl too, but the card doesn't seems to have a ground pole. Anyone thinking of doing the same, what are you gonna do?
Really interested to see what people think of this amp. Looks promising. Been on the look out for a decent upgrade from my magni+. Hope this isn't a limited offer.
For anyone on the fence, they've sold out of units with the ESS cards. I understand it's the same DAC module that's available directly through Schiit, but might be an indication that overall inventory is running low. I just ordered one without a DAC, so will gladly share some views on differences vs. the Asgard 3 to the best of my novice abilities when it arrives (which I know a few people have been curious about, myself included!).
