milkpowder
- Sep 22, 2005
Yeah, I did a search right after I posted and it does. How do you create the files though. I've got a load of 24/96Khz FLACs which I'd like to play at full resolution from iTunes w/o having to dither down / downsample to 16/48. In the meantime, I'm using Foobar...
EDIT: OK why did I never think of doing this. FLAC -> WAV via dBpoweramp, then import and convert straight to ALAC. Works like a treat. The main problem is the intermediary 24/96kHz WAVs are absolutely massive... The other problem being that I lose all the FLAC tagging when converting to WAV, then importing into iTunes before encoding into ALAC. If I go 24/96 FLAC to 16/96WAV, then straight to 16/96 ALAC using dBpoweramp, I don't lose the tags. Seems like iTunes cannot read WAV tagging (understandable though considering the nature of WAV). I wonder why the dBpoweramp ALAC encoder doesn't support anything higher than 16bit. I can't afford to spend time retagging the files as some the albums are a few dozen to a hundred tracks long (eg Linn Records - Messiah, Matthew Passion).
I'll try using WMA Lossless as the intermediary and then importing/converting using iTunes. The file sizes will be more manageable and tagging should be retained.
EDIT2: hmm doesn't work. WMA Lossless 24/96 gets automatically converted to 16/48 ALAC. Tags are retained though.
