On 0db gain Niimbus have like 32ohm/6W?
Niimbus Ultimate Series US4/US4+/US5/US5 Pro Headphone Amps - by Lake People
- Thread starter Fegefeuer
thecrow
- Oct 18, 2014
Is it 5.6 w at 32, 7 w?On 0db gain Niimbus have like 32ohm/6W?
https://power-holdings-inc.com/Niimbus-US-4-Headphone-Amplifier-p136295421
More than enough
roskodan
5.6W combined aka 2.8W per channel. Depending on the input signal level I wouldn't rule out the pre gain having an effect on sound. From what I can tell 0dB pre gain will already yield full power at 1.5V (+6dBu) input signal.
thecrow
- Oct 18, 2014
As mentioned I haven’t heard anything but that’s only from my own personal experience5.6W combined aka 2.8W per channel. Depending on the input signal level I wouldn't rule out the pre gain having an effect on sound. From what I can tell 0dB pre gain will already yield full power at 1.5V (+6dBu) input signal.
So Niimbus is dual mono AMP like Bryston BHA-1? 6,3mm output must be weak...
At least all my HP are balanced.
Fegefeuer
- Mar 17, 2011
4-PIN XLR out is also the only way to get all 4 amps inside moving.
roskodan
From what I understand, for 50 Ohms load and below, the unbalanced output power should be the same as the balanced output power. Because the limiting factor would be the current output. At least that was the case with the V281.
I can't wait compare US4 to my GS-X mini!
roskodan
Great, really interested in some impressions comparing these two legendary house sounds. Saw your setup in the "photo" thread, , the sexy TH-900 missing tho.
Yeah becouse my friend has them
acguitar84
I'm extremely interested in this comparison! I love the GSX mini - but in this hobby - what's around the corner you know?
Quite huge and heavy, almost didn't fit...
This Niimbus is really somethig else compared to my GS-X mini, is lighting fast (almost too fast), great soundstage, outstanding bass, clarity, sweet mids, only if he will be cheaper...
But i wouldn't paring Niimbus with bright DACs, highs can be harsh sometimes, my GS-X mini have more pleasant highs.
Still i am sure this is best AMP i have heard.
