LiuTim
- Feb 27, 2010
I'm looking forward to get a WA7.
Here is the sneak-peek in CanJam.
[size=22.0pt]WA7 [/size][size=10.0pt]prototype, estimated introductory price $777[/size]
[size=12.0pt]Tube headphone amplifier with USB DAC[/size]
- [size=12.0pt]Single-ended Triode pure Class-A, direct coupling[/size]
- [size=12.0pt]1 super tube 6C45 per channel, no semiconductors in the signal path[/size]
- [size=12.0pt]Handmade output transformer with Nickel Alloy core[/size]
- [size=12.0pt]32 bit/192k[/size][size=12.0pt] Asynchronous[/size] [size=12.0pt]USB DAC [/size]
- [size=12.0pt]1 USB and 1 RCA switchable inputs [/size]
- [size=12.0pt]High and low output impedance switch[/size]
- [size=12.0pt]Approximate max 1.5 watt/ch output[/size]
- [size=12.0pt]No visible screws in production unit[/size]
- [size=12.0pt]Separated power supply[/size]
- [size=12.0pt]Less than [/size][size=12.0pt]5[/size][size=12.0pt] cubic inches (amp)[/size]
- [size=12.0pt]Weights 7.5 lbs. with glass shield (amp)[/size]
[size=22pt]WA7 [/size][size=10pt]prototype, estimated introductory price $777[/size]
[size=22pt]WA7 [/size] [size=10pt]prototype, estimated introductory price $777[/size]
[size=12pt]Tube headphone amplifier with USB DAC[/size]
- [size=12pt]Single-ended Triode pure Class-A, direct coupling[/size]
- [size=12pt]1 super tube 6C45 per channel, no semiconductors in the signal path[/size]
- [size=12pt]Handmade output transformer with Nickel Alloy core[/size]
- [size=12pt]32 bit/192k[/size] [size=12pt]Asynchronous[/size] [size=12pt]USB DAC[/size]
- [size=12pt]1 USB and 1 RCA switchable inputs[/size]
- [size=12pt]High and low output impedance switch[/size]
- [size=12pt]Approximate max 1.5 watt/ch output[/size]
- [size=12pt]No visible screws in production unit[/size]
- [size=12pt]Separated power supply[/size]
- [size=12pt]Less than[/size] [size=12pt]5[/size] [size=12pt]cubic inches (amp)[/size]
- [size=12pt]Weights 7.5 lbs. with glass shield (amp)[/size]
around jan 2013 if i had to guess
