Originally Posted by PinkFloyd
Hi Jose,
The thump is perfectly normal and will not damage your headphones, don't worry! You'll notice the amp thumps with most opamps but is most noticeable with the 8065, I asked David about this and he said it was ok... can't remember the reason why I will ask him........ anyways don't worry about it it's just a short thump like someone whacking a drum (probably a very short dose of DC at turn on / turn off) it won't damage your headphones. You can always "hot plug" your 'phones once the amp is turned on.
Thank you very much, Mike. The thump is much, much louder than with AD8610 or LM6171, and real loud and frightening (perhaps my 32 ohm-impedance Grados are more susceptible or I'm not an enough brave headfier
Perhaps the best answer to this problem, whatever it is its cause, is the easier: to unplug the headphone before switch-off and after switch-on with no signal present (potentiometer set to max attenuation). After all, this is what a delay-relay does in many amplifiers: connect the load several seconds after turn-on and viceversa. With the dummy resistors in the socket the amp never sees no load at its output, and the brief contact that is made between "left live" and "right live" and ground (i.e.: a brief short-circuit in both channels) when pushing the plug into the socket every time I want to listen to the amp is inoffensive if there is no music playing. Am I right?
I've just measured DC offset at output socket without output capacitor and my multimeter read as follows:
channel A: 0.20 mV at turn-on and 0.98 at turn-off
channel B: 0.88 mV at turn-on and 0.488 mV at turn-off
It seems the AD8065 in channel B has a strange DC behaviour. Do you think it is defective? I've not measured DC offset with output caps, but I've heard the loud thump at turn-off even with them in place (but with output caps no DC is allowed to pass through them to headphones, isn't it?), and perhaps here lies another problem. If the cap-less amp is unexpectedly turned off (a power cut, for example), half a volt of DC goes to the headphones still plugged into it, which is bad, however brief is this condition. What do you think about it? (I know: I'm a chicken
Best regards
Jose
