The AD843 may be getting a bit long in the tooth (old) but still manges to get more right than it does wrong.I also like the "old" AD825 chip which again usually errs on the side of musical rather than the trend of most "newer" more modern chips which always seem to trend to the bright and slashy when caught out on busy sections of music with a lot of peak content in combination with a low level music foundation.They seem to lose the low level details while attempting to hit the massed peaks but fail even there mostly.
Just an opinion of course.YMMV.
On to servoed designs.I do not like them personally even though many swear by them.The servo in combination with negative feedback to me is a stage alwys trying to catch up and perfect instead of just passing along what is there.Play,compare,eliminate.play,compare,eliminat e,play,compare.......
With a discrete output stage DC coupling is attainable but again no eeasy path and there is parts aging which will cause at some point a D.C. offset requiring re-adjustment.this last is not within the capabilities or desire range of most headphone users so would be out for a commercial product but even for the DIYer who would want to always be paranoid about the D.C. and instead of enjoying music worrying about his and checking for D.C. conmtent ?
So what is left ? Capacitor coupling or transformer galvanic isolation.The first is the cheaper path and one that can provide good results depending on the capacitor selected.Being a single part it is super easy to pop out one cap and pop in another to check the sonics and once you arrive at a good result-solder that puppy in and close up the box then go enjoy some music.
The second option is neither cheap nor is there many oiptions out there though why i do not know considering the amount of headphone amp activity lately from all the major players.Sowter has one that goes dead flat from 15hz-30khz and is 10 ohms effective as seen by the circuit so a possible solution but to my knowledge the only headphone specific transformer readily available.Oh you,it will cost about 10X the cost of even the most expensive caps so not a cheap option though potentially a better option sonically.
Just adding to the conversation folks
