Sophie 101
- Oct 16, 2016
HI guys,
I know what a DAC is, but I don't know if I need one
Perhaps if I try and explain what I want to achieve, someone can shout at me, can they?
I have a pair of Yamaha MSP-5 active speakers lying around that I want to build a system with in the lounge. I have an iPhone SE ( with the 3.5mm audio out) that I want to run into with the speakers. I listen with my headphones when out and about.
iphone SE outputs are:
3.5 mm analog
USB audio via a lightnig to usb cable ( never tried this before).
Yamaha MSP-5 inputs are:
XLR balanced
1/4" balanced
Music app
I have only used VLC for iOS. The audio files are not stored in itunes, but instead stored inside the VLC app. I read itunes/apple music app will convert the AIFF to AIFF-C or something.
My initial thought was to run the 3.5mm analog through a 3.5mm to XLR converter cable from amazon. Cheap and easy.
But is the best way to do this? How will this sound? How good it the 3.5mm signal?
If I run the USB-audio then is the signal downsized to 44k/16bit or can I actually send out a better signal to my speakers? ( speakers have 50 Hz - 40 khz range).
I looked at the Oppo HA-2 SE for the DAC because it sends out both a line-out for the speakers, and a 3.5mm headphone out for my cans, which means it can double for home use system or a portable headphone systems. Also I can run in 3.5mm analog from my iphone and listen to my headphones.
But does this really matter if all my music files are 16bit/44.1khz AIFF files?
I have no idea. Does anybody else have an idea?
Thanks,S!
3.5 mm analog
XLR balanced
1/4" balanced
Music app
Thanks,S!
