goody
- Apr 2, 2009
My $3 silicon case from Taobao arrived today, perfectly fitted, and quite nice !
Nice any links for this case will check aliexpress also
mine doesn't lack bass whatever i do: play it cold, warm, right after pause, after an hour of listening etc - it always sounds the same, no issues.But in my experience, this issue only appears when you "wakeup" the A300 by start to play something, most likely because the capacitors discharge.
Listening to local files?mine doesn't lack bass whatever i do: play it cold, warm, right after pause, after an hour of listening etc - it always sounds the same, no issues.
I am.Are you connected to Wi-Fi at all times?
Just looked/tapped mine and I'd say the Top & back is one piece (L shape) and made of plastic. The main casing is milled aluminium.That's one of the benefits of having a digital amp, low power and cool runnings. I'd venture the back is plastic like previous A Series.
I find downloading over WIFI faster & more reliable than on the W1AM2 I had.Well I completed the factory reset, reloaded my apps and downloaded my music onto the Micro SD storage…
Thankfully, the bass remains, still no issues there.
Only issues that remain are:
-Low feedback static when on wifi
-Some lag when downloading (better in this regard than the ZX507, slightly worse than the WM1AM2)
Those times of 36 hours will be playing mp3 or 96FLAC in Walkman Music player at 50% volume with no screen use & wifi/BT turned off. No other app running. Also, DIRECT mode and no Hi-mode. Also from full charge, not the Battery Care mode level.I am.
Thanks for the video, I'll check it out.
Manual is here: https://helpguide.sony.net/dmp/nwwm1m2/v1/en/print.pdfA306 Power Usage
Being new to this technology I read battery life was to be claimed as follows:
"Up to 36 hours on 44.1kHz FLAC playback, up to 32 hours on 96kHz FLAC high resolution audio, or even up to 26 hours with the streaming service apps."
Mine certainly doesn't 'appear' to be getting anything like that so I wanted to check a few things.
When I set mine up it imported various things from my phone some of which I didn't want on my Sony.
I attach which Apps I have on the A306 and also, the only two I have open when using the device
I don't leave the screen on and it's not overly bright in my view as you can see
Volume varies between 50/120 & 80/120.
You'll see from the next image my playback since last charge is nothing like the above figures, so what's draining it?
Any ideas as to what adjustments I could make or thoughts as to why it's not achieving the remotely close to the quoted figures?
Thanks in advance.
I am only playing Flac / mp3 files.Those times of 36 hours will be playing mp3 or 96FLAC in Walkman Music player at 50% volume with no screen use & wifi/BT turned off. No other app running. Also, DIRECT mode and no Hi-mode
You posted WM1AM2 figures !Manual is here: https://helpguide.sony.net/dmp/nwwm1m2/v1/en/print.pdf
- EQ/DSP has major impact on battery life
- Higher bit rates have major impact on battery life
NW-WM1AM2/NW-WM1ZM2 Battery life Music (when using “Music player”) Stereo mini jack MP3 (128 kbps) Approx. 40 hours AAC (256 kbps) Approx. 40 hours WAV (44.1 kHz/16 bit) Approx. 40 hours FLAC (44.1 kHz/16 bit) Approx. 40 hours FLAC (96 kHz/24 bit) Approx. 40 hours FLAC (192 kHz/24 bit) Approx. 35 hours DSD (2.8224 MHz/1 bit) Approx. 25 hours DSD (5.6448 MHz/1 bit) Approx. 18 hours DSD (11.2896 MHz/1 bit) Approx. 15 hours Balanced standard jack MP3 (128 kbps) Approx. 40 hours AAC (256 kbps) Approx. 40 hours WAV (44.1 kHz/16 bit) Approx. 40 hours FLAC (44.1 kHz/16 bit) Approx. 40 hours FLAC (96 kHz/24 bit) Approx. 40 hours FLAC (192 kHz/24 bit) Approx. 35 hours DSD (2.8224 MHz/1 bit) Approx. 15 hours DSD (5.6448 MHz/1 bit) Approx. 13 hours DSD (11.2896 MHz/1 bit) Approx. 9 hours Music (when using a music app other than “Music player”) 141 Stereo mini jack MP3 (128 kbps) Approx. 18 hours Balanced standard jack MP3 (128 kbps) Approx. 18 hours Bluetooth (when using “Music player”) MP3 (128 kbps)/SBC-Connection pref. Approx. 20 hours FLAC (96 kHz/24 bit)/LDAC-Connection pref. Approx. 18 hours Bluetooth (when using a music app other than “Music player”) MP3 (128 kbps)/LDAC-Connection pref. Approx. 17 hours A Bluetooth connection will shorten the battery life by up to 60% depending on the following conditions. Format of the content. Settings of the connected device.
Note: The values shown in this topic indicate the approximate battery life when the player is playing continuously with the default settings.
Even if the player is turned off for an extended period, a small amount of battery power is still consumed.
Battery life may vary depending on volume setting, conditions of use and ambient temperature.
The battery is consumed considerably when the screen is on.
The battery life may become about 60% shorter when some of the sound adjustments are active.
The battery life may become about 20% shorter when the [High-Res streaming] function is active
I'm going to fully charge it, turn off Wi-Fi and leave it playing at 50% volume via my Hi-fi to see that I get.
Anything else recommended?
