yeah, strange, have read previous posts, seems like only mine not working, keep charging to full 100% with battery care, quite worrying to shorten the battery live.Strange, it always worked fine for me
New Sony Walkman NW-A300 Series (Android 12)
captblaze
Pre-update - Charge to 100% with Battery Care on
Post-update - Charge to 94% with Battery Care on
both times device was powered on while charging
not for me since the android 13 update. hopefully this new update fixes itStrange, it always worked fine for me
By the way, anyone knows how to get to the recovery mode for A306 with Android 13? I have tried with power button + Vol-, and other combinations, but to no avail.
Im just trying to do a factory reset from the recovery mode, seems some bugs cannot be fix thru regular factory reset.
captblaze
can you turn on developer mode and adb your way into recovery mode?By the way, anyone knows how to get to the recovery mode for A306 with Android 13? I have tried with power button + Vol-, and other combinations, but to no avail.
ah, maybe I will dig up some adb notes, hehe. Just hoping an easier way, last resort.can you turn on developer mode and adb your way into recovery mode?
MrWalkman
Turn the player on while keeping Vol+ pressed I think (if I remember correctly).
When you get into the recovery, hold power, press Vol+ once, then release power to show the normal recovery screen with all its options.
Have tried that too, doesn't work, it will stay at the Sony screen intermittently, when let go, it boot up normally as usual. I have even tried the ZX507 method with power + skip next and play buttons together, no avail too.Turn the player on while keeping Vol+ pressed I think (if I remember correctly).
Tried with ZM2 with android 11, it works with power + Vol- buttons. Hmm, maybe android 13 or A306 has different configuration.
MrWalkman
Try Vol+ and Play at the same time, there is a certain combination for sure, I had the device for a while, or Vol+ and Skip.
Nope, Power + Vol+ and play do not work too. I even try power + Vol- and play. Think Sony has lock it this time.Try Vol+ and Play at the same time, there is a certain combination for sure, I had the device for a while, or Vol+ and Skip.
Hinomotocho
I'm just initiating the update now - mine seemed to always charge to 100% with battery saver on.
I use Android phones but I'm new to Android for a dap, do any of the general Android optimization settings in that guide need to be set again after an update or should all those settings remain?
* post-update: my battery was about 74%, I connected to a charger for the process, after update it was charging up to 88% before I had to leave for work.
thr4
Interesting. Battery Care worked once for me (on Android 13) and then stopped. Good to see it's fixed.
Hinomotocho
Can you get hold of a ZX300? I owned one, then a 1A, now a 1Z. Having followed those threads for a few years, the ZX507 would be mentioned, and from memory, some owners rated it above the ZX300 for sound, but is pure Sony OS - this was pre-firmware mods.Used ZX507 for less than new A306
Does it make sense to pull the trigger on a used ZX507 if I can get it for $100 less than a new A306 about $360 CDN?
I really don't want an android DAP but at this price using it for local tracks only makes it worthwhile given it still sells for $1200 CDN new. Not worried at all about android version since I won't be using wifi or streaming.
I favour the Sony OS, but I wanted the small form for a daily dap, and the ease of USB-C to charge anywhere without having to carry extra cables.
There are people on the WM1A/1Z thread that have clocked 10,000+ hours on their players on the original battery and say they barely notice any loss of playback.
fish1050
My only reservation is I have never owned a full android DAP before and not really sure how much stuff I can deactivate or remove. I have plowed through alot of the ZX500 and having very little android experience not sure I want to have to do all that work to get it stripped down to fit my needs and how much crap will still be left after.sounds like u already made ur decision
Of course there is always the wife factor and any purchases need to addressed with her first.
fish1050
Actually I was looking at a used ZX300 and the used A55 I bought both with the MrWalkman firmware in mind. I nearly pulled the trigger on a ZX300 but users on this forum convinced it wasn't worth the extra money for the ZX300 so I got the A55. From a portability standpoint probably the better choice and I didn't need a balanced output.Can you get hold of a ZX300? I owned one, then a 1A, now a 1Z. Having followed those threads for a few years, the ZX507 would be mentioned, and from memory, some owners rated it above the ZX300 for sound, but is pure Sony OS - this was pre-firmware mods.
I did considered a WM1A briefly but not portable at all which is my main use for a DAP.
My A55 is still working great so the other option is to stick with it and see what deals if any come up for the A306 around Black Friday this year. I am not above getting something used but the older the DAP the greater the chance it is heavily used and may not last that long. I could opt for a used A105 but it would probably not sound as good as the A55 with the custom firmware but less of a financial risk.
Total: 36 (members: 0, guests: 36)
