Curious if anyone owns the MAP-S1. I have mine connected to a Winbook TW802 (one of the few tablets with a full size USB port) running JRiver MC20. Paired with a set of SS-HA1 speakers and I finally got my spouse's seal of approval.
New Sony high-end DSD gear, including a USB DAC
- Thread starter shuttleboi
cuiter23
The MAP-S1 looks like its built like a tank
- Aug 2, 2013
The entire lineup (uda, hap, etc) is built with great quality
^agreed.
lenroot77
- Mar 9, 2014
Anyone interested in a UDA-1 @ 200 dollars send me a pm. Thanks
SOLD
SOLD
znil78
- Jan 26, 2011
The SSHA3 pairs reslly well with UDA1 as well, its what i use in my office.
sluker
- Feb 13, 2010
I have to say that the ability to burn CD's in FLAC right to the drive of the HAP-S1 is killer. I am now going to need to attach an external HD as previously I have not converted all of my CD library because it was such a hassle and only had my most listened to music there in digital.
This changes all that.
KetchupNinja
- Aug 14, 2012
SOLD
If anyone else has a UDA-1 for sale, I'd be interested!
Devils Trill
- Nov 8, 2015
Yeah, this is a killer feature. Have you used it a lot? I'm curious as to how it works and what options are avialble when you burn directly. Like, can you join tracks or anything fancy like that?
Thanks.
Dionysus
- Feb 6, 2009
Essential you have 2 options Wav and Flac. And you can also have it burn slow and fast meaning it will burn your cd with more error correction at the slow burn option. Hope that helps as far as other cd burn options, this is what I remember and I've burn 20 or 30 plus cd thus far.
svmusa
Curious - with Ethernet connection is it possible to use this as a DAC while playing youtube etc where there are no source files as per say?
McGilli
- Sep 15, 2015
Does your cd drive have external power? Mine needs to draw power from the USB bus, and it works up until it's time to actually rip the disc - and then it won't actually fire up and rip it - just sits there no matter what disc I try. I'm guessing it's a power issue since the instructions on screen even say connect cd drive with external power
Dionysus
- Feb 6, 2009
Well I use the Apple USB Super drive no issue, just plug to the USB hub on the Sony HAP1Z and I'm good.
McGilli
- Sep 15, 2015
Thanks - I'll keep trying - I'm using a cd drive from my Macbook Pro that I put into an external case and usually just use with all my Macs....
TheGrumpyOldMan
- Feb 19, 2012
Different CD/DVD drives can have different power draws, and burning needs more than reading/ripping, so results may vary because of those factors.
Sony specifically mentions using a CD/DVD drive with external power supply because most likely their USB ports were not designed with this amount of power draw in mind. If you don't have such a drive, you can try using a powered USB hub (i.e. with its own power supply) as an intermediary between the USB-powered drive and the HAP.
(Alas can not confirm because all my ripping & burning is computer-based, I only transfer the final files strictly for playback)
