Mixcder
Member of the Trade: MixCDer
- Oct 14, 2016
I got some unexpected listening time in yesterday too so I am ahead of schedule - my review is up.
Thanks again to Mixcder for this opportunity. I hope they will continue to offer these review samples so others can get to know this brand. As for me, I'm keeping my pair and ordered another for SWMBO.
My initial listen was during and after a hard run, whilst daughter practiced at goalie training. I must say it was a typical Midwestern WINDY evening, with beautiful clouds.
This afforded me two findings right off the bat: isolation, and fit during a rigorous workout (no, really!). While I could hear the wind in my ears, it was much less than expected. I was very happy with the enclosed and mounted silicon tips.
And as for fit, I had no problems what so ever with running the X5 cable down. The little critter (OK, notnso little) stayed put, period. No movement at all. Again, quite happy, since they were run cable down.
As for my initial sound impressions? I am satisfied with that, too. A good solid sound, highlighted by what I will call "exuberant" mids, highlighted a pretty solid initial impression.
Good reach of bass, wasn't balanced by good reach of treble, though. Of course, this is only 1.5hrs into my listen, too. My hope is that the treble will open a bit, to balance the mids and bass.
The shape to me matches the excellent Dunu Titan 1, once of my first forays back into the portable world, and a worthy one to mimic!
Well done, so far!
A little sooner than I would have preferred but here is my Review:
http://www.head-fi.org/products/wired-earphones-mixcder-x5-in-ear-earbud-headphones-metal-housing-with-mic-noise-reducing-for-3-5mm-audio-output-iphone-and-other-smartphones-black/reviews/18468
Thank You so Much Denise for this opportunity.
TWIN
Am I last? Here is my review:
http://www.head-fi.org/products/wired-earphones-mixcder-x5-in-ear-earbud-headphones-metal-housing-with-mic-noise-reducing-for-3-5mm-audio-output-iphone-and-other-smartphones-black/reviews/18476
Like TWIN I would like to express my gratitude to Denise and Mixcder for the review opportunity.
Scott
I'm definitely going to be last, I haven't even received the earphones yet!
Scott
We are so sorry for the slow delivery. @ areek @ ryanjsoo @ Deviltooth
Reviewers outside USA&CA, we sent the sample out from China instead of Amazon FBA. But it is quite strange that the info has not updated since April,13. Will check with the forwarder.
Hello My friends, So glad to see all the reviews. Thank you so much for the hard work. But we noticed that some of you mentioned that a week is too short to review a brand-new product, I am not a professional reviewer or an audiophile and I am really sorry that I asked for a review within a week since the receipt.Can you guys let me know how long do you usually need so we can have a better and more reasonable time schedule for our next review round.
Many thanks in advance.
Tough to give a single right answer here. In most cases it depends on the product in question, the reviewer's schedule, and the depth of comparisons to other products or the use of the product in different environments.
Product: I've had some headphones that took a lot of burn-in to really do their best work. If I had reviewed those with less than 100 hours or burn-in time, the review would not have been the same as it was after that mark. I think the KZ-ZST is a good example of that. Out of the box they tend to be muddy at the bottom and piercing at the top end. With some time on them and a 48 hour pink noise session, they calm down a good bit. That is not to say they become a completely different product, just that they improve enough that reviews based on taking them out of the box and immediately doing listening impressions are generally less positive and much more likely to note sibilance and loose bass.
People will argue that burn-in isn't a real phenomenon but whether you believe in it or not, its a proven fact that most people will review a product differently after 100+ hours of use than they would when reviewed as soon as it came out of the box.
Personally, I think anything with moving parts can benefit by giving it some time to break in as tiny bits of glue or burrs etc. can be worn down with use.
Reviewer: On slow weeks, I can usually listen about six (6) hours a day and this gives me enough listening time to generally form a pretty good basis for review in three (3) or four (4) days. On busy weeks, I may only get an hour (1) or two (2) in, and this means it may take me eight(8) - ten(10) days to get that same amount of time in.
Comparisons: Every product you compare to the review sample requires you double the amount of listening time in order to really draw a solid comparison. If you pick six test tracks (roughly 30 minutes of music) and listen to them each 4 times per device, this can quickly grow into a number of days. For me, I listen with the test sample, then with Comp1, then start over and listen with the test sample again and then with Comp2 and so on to make sure the test sample stays fresh in memory when drawing comparisons. I try never to listen to one member of a comparison on one day and the other on a different day as it introduces way too many variables to really do justice to the comparison. Basically the same can be said for changes in other parts of the audio chain. If testing a single set of headphones with multiple sources, you again have to do an A/B test for each change you make to really be able to compare. Again this means doubling the listening time for each swap.
As reviewers, we understand too that the manufacturer providing the sample is after two things that can lead in opposite directions. First and foremost, they want a solid review and with any luck a positive one. This is not to say they expect misrepresentation of the product, but that they want their product presented in the best light realistically possible. For example, it would be preferable to say "Good Bass and solid mids with some flaws in the treble" instead of "Despite some good characteristics, the treble makes these unlistenable". As reviewers we have to remember that each person is different and not apply our personal biases to the review in a way that negatively depicts the product. For this reason, I usually re-read my reviews before posting to make sure I have not made negative statements that show a personal preference or bias. The second goal is a timely review as no manufacturer wants to think they sent out samples only to get nothing in return. For that reason, most review tours give each person a week to listen and then the expectation is you write your notes the week after your listening session and post your review then. (This gives 2 weeks total).
For others, I am sure their process is different, but hopefully that gives you a little insight into my process and my thinking.
Wiljen
