George Taylor
I know you've posted photos of your wooden headphones before. It would be amazing to see you try to get your entire collection in a shot. Or several.The number is actually > 100 (closer to 200 than 100)
Even though the Odin is a planar headphone needing relatively much current, it should to theoretically be quite easy to drive with its low impedance and high sensitivity. Could you guys please share your opinions on this? Would 8Vrms out of an AK380 amp (balanced) be enough to make Odin really shine? Did anybody try the Odin with DAPs?
Hi.
Before I had my current amplifier (Viva 2A3), I was the owner of an hybrid Rudistor amplifier RP8K-VT outgoing 19 Vpp (6.7 Vrms) out of 35 Ohms (ie 1.3 Watt on the load of 35 Ohms of the Odin).
No problem to drive the Odin effectively.
@earfonia in his great review of the Odin (on Head-fi) (see bottom of page of the link below) offers us some figures concerning the minimum power and the recommended power to effectively drive the Odin.
Quote: " Amplification & Gear Pairing
The loudest volume I ever set to play some soft sounding recordings was around -10 dB on my Geek Pulse XFi unbalanced output, at high gain. My listening volume is generally around -20 dB. The -10 dB unbalanced output was measured 2 Vrms on my oscilloscope, while -20 dB was around 0.64 Vrms. Therefore any player or amplifier that is able to output 2 Vrms at 35 ohms, or approximately 115 mW output at 35 ohms, would be able to drive Odin with sufficient loudness. These days, many modern DAPs have 2 Vrms maximum output or more, with output power ranging to a few hundred mW. Those powerful modern DAPs would be able to drive Odin with sufficient loudness. Adding an additional 6 dB headroom, in the case that louder volume is required, it is translated to -4 dB volume on my Geek Pulse XFi unbalanced output, which is 4 Vrms, which is approximately 460 mW output at 35 ohms. 500 mW output is quite common for desktop amplifiers, and not considered high power output. Therefore we can conclude that Odin doesn’t require high power amplification, and relatively easy to drive. Any source with around 150 mW output at 35 ohms would be sufficient, and around 500 mW (or higher) output at 35 ohms is recommended for Odin.
Odin is easy to drive in the sense that we could get adequate loudness even from a not so powerful DAP. But from my observation, bass will suffer when not properly driven. Bass may sound loose and less textured when not properly driven. When properly driver using good amp, bass is clean and tight with realistic texture.
During the 2 months period with Odin, I’ve tried Odin with some DAPs & DACs such as AK70, Onkyo DP-X1, Cayin i5 (only short period), Chord Mojo, Chord Dave, Geek Pulse XFi, ifi micro iDSD + iCan, Yulong DA8, Questyle CMA800i, Questyle CMA600i, Matrix HPA-3B amplifier, and some other amps. Odin with its musicality can easily sound good and enjoyable with all of them. But it doesn’t that Odin sounds more or less the same with all of them. Odin clearly reveals the source and amp signature quite well, but it has the ability to sound good with most gears. For DAPs like AK70 and Onkyo DP-X1 using the balanced output is highly recommended for extra power and better driveability. The 3 most frequent sources I used during this review is the Geek Pulse XFi, Questyle CMA600i, and Chord Mojo. My personal preference for Odin is the Geek Pulse XFi which gives a tad extra body to the bass for a more engaging musical experience. Questyle CMA600i and ifi micro iDSD + iCan combo are also highly recommended for a faster transient and dynamic. So even though Odin is easy to drive, but it also scales well with some gears that match well with Odin's sound signature. "
https://www.head-fi.org/f/showcase/kennerton-odin.21886/reviews
@eric65 Sorry if I missed this earlier in the thread, but are you associated with Kennerton in any official capacity? Or just passionate about them. Just wondering
Thank you, Eric65.
I really enjoyed the sound of the Kennerton Odin at the "High End" in Munich. Detailled, not too cold, present highs but without fatigue, relaxed, without any serious shortcomings. So I will probably buy the Odin some time in the future, if I can get one for a decent price. Mk2 is very heavy still, but the weight of Mk3 will be more to my liking.
Continuing love for both the Odin and Vali here! (Nothing new to add, just wanted to give a shout out )
Still will probably get another Vali, to balance out my two Odin's. I'm glad you all can relate, and know the passion.
Anyone know if Kennerton does a t-shirt?
