REB
- Jan 15, 2008
sylvania gold 408a
sylvania gold 408a
I've never been a fan of those to be honest, but if it's doing what you described than the the tubes are defective. If you want another pair that I know work with mine perfectly, let me know and we can work out a deal for them." class="bbcode_smiley" height="" src="http://files.head-fi.org/images/smilies//smily_headphones1.gif" title="" width="" />
Are you 100% sure the jumpers were set correctly? Did changing the gain setting help at all?
(They are sylvania gold, not gold pin)
Well, they were my favorite tubes, but I'd rather have them gone than the amp. I am interested in a deal for another pair though!
The gain settings are correct. i didn't change them after I got the amp, i've always used tubes from this family. and I think I have about a thousand hours on these tubes. I would have noticed before if the gain settings had not been correct.
Soon, I'll be getting the W1000X and use it with my LDI+. I'm assuming the results would be good as well.
What does the LDI+ do for your W1000?
Have you tried cleaning the pins of the Sylvania's with DeOxit? Not sure of the history of your tubes but I'd give that a try before giving up on the tubes altho I admit its a long shot.
That sucks! have they played that many hours already?
i've just joined the LD I+ party with OPA2107 and WE408A installed
1 of my WE408A had no sound.. i had extras and the next one that i swapped in worked.. likely to be a dead tube?
Yes, if you replace the tube and the sound comes back that's all we can assume, however you could try cleaning the pins... though I don't know if the amp is prepared to operate correctly with bad tubes. Tube amps are funny animals. I would clean the tubes with a wire brush, and then deoxit, then tube brush. (wire brush being abrasive enough to really clean off all the tarnish)
I don't reccomend a wire brush for gold plated pins as it will likely remove the gold plating.
hi,
i did some light cleaning with q tips and MG super contact cleaner (same idea as deoxit, but available locally) when i received the tubes, but the condition of the pins on all the tubes looked the same.. i bought 4, with 2 in the amp now and 1 with no sound (so far) and 1 that i haven't tried yet as one of the pins is slightly bent one way... can i gently bend the pin back with pliers?
i'm not in a hurry to replace the existing 2 tubes as they work fine and i'm just gonna listen to it more first..
thanks!
