Dobrescu George
Reviewer: AudiophileHeaven
like drowning battery or something else ?
i had not depleted completley the battery yet. 8 hours a day max without recharge. 2 hours max for recharge.
It is pretty nice.
Hello, I am a starting member. I own a Rock-It R50 and just acquired the ATH-M50X. I am using my old Ipod Classic, my Samsung Galaxy Note 4 and the Samsung Galaxy Note Pro 8.4 as music sources. I need assistance on how can I improve the sound for my IEM and headphone.
I have been reading and learning the benefits of the Fiio E12A for IEM's as well as headphones. Would I be wasting my money buying this class of amplifier? Are there better recommendations for my gear? I want to listen to my phones with quality and better listening volume levels. Also want to get the most of my sources.
I would use ipod classic via LOD with Fiio e12 for example
Thank you all for your support, my music has a combination of mp3 (recorded with variable bit rates) and AAIFF files. The volume I get from my Galaxy Note 4 using the ATH M50X is not enough for my listening needs. The Ipod Classic has a better volume output but also falls short. With an amp in my configuration I can use a LOD cable to connect my Ipod and was thinking on also buying an HifimeDiy Sabre Android DAC to connect to my Galaxy Note 4 and bypass its internal DAC. I would probably go in the future for a better music source, so whatever I buy at this time should be also usable with better resolution players.
Thank you bavinck, do you have a recommendation for an amp besides the e12A (in case I want to use my actual musical sources)? Fiio X3K (2nd generation) or Ibasso DX-50? Do you know if I can connect my Galaxy Note 4 to the DAP's with a OTG cable?
I am also evaluating going for a DAP. Fiio X3 2nd generation or the Hidizs AP100. Someone has a recommendation?
