llmobll
- Jan 27, 2004
well i wasn't going to post, cause there are so many threads like this but...
1. If you are deciding on ditching the duron, just get an old school Athlon XP i HIGHLY recommend the 1700+(if you can find them). I would just get the model that is cheapest if you aren't going to overclock. I will outperform your duron and its the same price on pricewatch.com $44
2. The wattage of a PSU is MOSTLY dependant on two things. (1) CPU/Brand (2) HOw much load you are going to put on it. From your specs you're going to be using a less power hungry CPU, with very little load.(ie. you're not running 3 HD's and a powerful vid. card, with 20 fans) I would shoot for 300watts of a quality brand. In reality you could get away with 250 even 200 if its a good supply. I tend to stay with the name brands, antec and the like, but a decent unit will run about $65 or higher.
Last thing i want to mention is, many people argue system instability can be attributed to a bad quality PSU. I've been throwing these boxes(comps.) together for about 8 yrs. and I've had ONE incident where a PSU was the cause of bad system performance. It turned out to be a bad PSU.
The way you diagnose a bad PSU is run Monitoring software, Motherboard Monitor is good, and simply look at your Power rails, are they normal? Do they change with more load? The biggest contributor to bad system performance is a bad motherboard(ECS) design and poor configuration of the operating system.
good luck
good luck
