nzvlam
Hi!
I am just new forumer here.
My only concern with the Burson Conductor V2 is that it may lack the higher reserved power for transients/dynamics specially at high impedance headphones around 300 to 600Ohm plus the low sensitivity level of the cans within this range of Impedance. please correct me if i am wrong but 500/250mW is a bit low in terms of "raw" power and the voltage in can deliver during peaks and dynamics when playing a signal. Also, i am not sure why they didnt include a balanced connections in this amp, yes properly implemented unbalanced will still sound superior compared to balanced connection but i dont think Burson will, make a crappy implementation and make it the weakest link of their product.
I love Burson, i have one the Soloist SL and modest Shure SRH 1840 and i am tempted with the Conductor V2, but what makes me think twice of buying the Conductor is the reserved power and the balanced connections. Ofcourse if i want to upgrade I will definitely go for the top-tier Headphones and most of them have a high impedance and of course the way how hard its respective drivers can be driven.
Please let me know, "if my perceptions" are relevant or not.
I know that's what the numbers say, but numbers alone don't always tell the full story, do they?
As mentioned by lots of head-fiers, the previous Conductors are brilliant in driving the Audezes, which are harder to drive cans. I don't have any Audezes so I can't say if that is true or not. However I certainly have no problem using the old 4watt only first gen Conductor with my Beyer T1 (actually works really well!). All it needs is med gain and about 50% volume, and that's enough to make you deaf in some louder music. Granted the T1 is probably the easiest to drive 600Ohms out there, but the Conductor certainly have no problem driving my 300Ohms Sennheisers.
Just to throw in the mix, as many people would say one of the most (if not the most) difficult to drive cans out there, the Hifiman HE-6. The Conductor has no problem driving the HE6 to a sound level that will deafen your ears, but I do find Hifiman's own EF-6 a better match with the HE-6. In contrast, the Conductor does not give the upper lows, and the mids like the EF6 does, hence the HE6 sounds a bit shouty, bright and not that enjoyable. But that is just the signature of the Burson being more neutral. Other than that (or may be AKG's K1000), I don't think you can find any headphones out that the Burson has not got the power to handle.
Victor
