raoultrifan
Great news about the low-noise stuff. Waiting for close-up pics from the inside.
Hey!
" The new batch contains a few improvements both on built and sonic performance. Its remote control is further refined and its aluminum finishing also goes up a level. In terms of performance, it is also a step forward. Especially when powered be certain types of budgeted PC internal power supplies, the new revision is better at filtering and conditioning power resulting in a quieter background when paired with sensitive headphones. "
kebcy
I've talked with Alex about it, they've made a mistake in manual and it's fixed right now when you check their website. They use 2x I/V and 1x LP as @raoultrifan stated in his posts earlier.I'm still a bit in doubt about the I/V and LP stages. I think I will ask Alex for clarifications, because I've asked for a customized build - V6 Vivid in I/V and Classic in LPF.
The one I had was customized with one V6 Vivid in center and the Classics in the left and the right - accordingly with their schematics.
NO ASIO4ALL!!! Just install the XMOS driver from Burson downloads webpage, get your PLAY connected and that's about it.
Make sure the XMOS/PLAY card is not the default soundcard; the onboard card should be the default playback device. XMOS (PLAY) should be manually chosen as playback devices on your software/player.
Usually Foobar and jRiver are the ones most people is using.
In case you got some really sensitive cans around, perhaps some 16 ohms IEMs, it would be good.
Eiffel, not sure what you posted above, but this is not what's inside the PLAY. Please read https://www.head-fi.org/threads/new...mp-rollers-dream.860882/page-25#post-14133736. There's nothing to improve to I/V nor to LPF inside PLAY, unless you want to heavily mod it with resistors instead of opamps or with Luhmann transformers (not recommended anyway, not much space inside for that).
The improvement everyone else is waiting is definitely related to what kebcy said before" "the new revision is better at filtering and conditioning power resulting in a quieter background when paired with sensitive headphones".
P.S.: The 2 x SS V6 Classic are the I/V stage and the Vivid is the LPF. Please read the last 2 pages and also the link from above showing the schematic from inside PLAY and https://www.head-fi.org/threads/new...mp-rollers-dream.860882/page-23#post-14128905.
Thanks for clarification, in this case I have to talk with them to change the customisation before they send it to me.I've talked with Alex about it, they've made a mistake in manual and it's fixed right now when you check their website. They use 2x I/V and 1x LP as @raoultrifan stated in his posts earlier.
Thank you!
So I simply let it on enable, but how do use this under games? I mean.. I still have to choose the XMOS? I guess.
Well, Beyerdynamic Amiron considered to be a pretty sensitive planar can, if I am not mistaken, yeah?
Also the remote I had was not well finished - not anodized aluminium, but painted - started to exfoliate a bit inside.
The reason why is not recommended to set it up as default playback audio device in Windows Sound panel is that while doing critical listening you don't really want another software from your computer to start playing something (your open browser or another software).
I really dont know what's wrong, I've never had problems with my Fidelio X2+ V-moda boom pro mic before the Play. Before the Play I was using a Creative X7. I've been in contact with Burson and they've been very responsive but cant pinpoint the problem.
C-Bass are you using the 6.35mm adapter that came with the Play? When did you receive your unit? Do you hear any static noise if you use the volume wheel on the V-moda cable?
I've also been having problems, that were referred here, with the headphone port, it seems a bit loose and if I use the 6.35mm adapter whenever i touch headphone 3.5mm plug i get some static. If I use cable ending in a 6.35mm I dont get this.
Any suggestions? Should I test the Play on another computer ?
