Hi everyone!
I have thoroughly enjoyed reading the whole thread and keep on top of it, as well as interact with the many people here.
Big thanks to
angelom for starting and maintaining it of course. I will admit he was the motivation for me to get the B&O H95 in the first place.
So... I thought it was time for me now to make a small contribution to this thread as well, and to provide my perspective to maybe balance things a little, as someone who owns both the H95 (for two months) and the APM (for one month).
I see a lot of love for the H95 and I think it's well deserved, they are an amazing pair of headphones.
At the same time, in my opinion, I do
not think it is fair to say that they are
de facto better than APM, as may seem to be the case from some posts here.
It's a bit more complicated than this, and likely what made me decide to share my impressions of both.
To start off - price was not a (major) consideration for me, I simply wanted the best ANC wireless headphones that I could find.
So I started my journey buy ordering H95 online (APM was not yet available at that time), but not before also trying the Sennheiser Momentum 3, Aonic 50, Sony XM4, B&W PX7... they all went back and H95 stayed. When APM came out, I ordered them as well, as for the past 1 month I have been comparing both side-by-side in my daily routines, which include music listening (mostly EDM, indie, pop and of course classical) and day-to-day working from home needs (phone calls, VOIP conference calls etc.). Also worth noting, I am mostly an iOS/Mac user for home and a hybrid of Mac/Windows for work. I use ANC and Transparency mode regularly. Sometimes listen to Music with Transparency mode ON to be able to hear my environment.
I use both the APM and H95 with their default
stock tuning and haven't done any EQ (and not planning to).
I don't want my post to be too long, so maybe I will use the bullet format to summarize my thoughts.
I will try not to repeat my findings (e.g. one's Con is sometimes another's Pro).
B&O H95 | AirPods Max |
Pros:
* Pleasant sound signature with a more 'open' midrange, great treble
* Slight edge to detail retrieval/resolution compared to APM
* Simply amazing battery life, lasts about 2x longer than APM
* One of the softest and most comfortable real leather ear pads
* Touch controls are better implemented than the competition
* Beautiful design and good choice of materials
* Comfort - 7.5/10. Good comfort overall. Pads are soft and amazing but ears start feeling hot after 3 hours of wearing them, around same time I start feeling pressure from headband (reference is Denon 9200 as being 10/10 for me)
Cons:
* They are 'windy' headphones... when ANC or Transparency modes are on, even by walking indoors I get 'wind' in my ears that the microphones seem to amplify. Outside is even worse. No such issue with APM. No such issue when H95 are used in the "Off" (Neutral) mode.
* Everyone says they are amazing build quality... maybe I am too picky, I expected better build tolerances. I did not appreciate the 'wobble' and uneven tension of the Volume and ANC rotary dials that both my H95 pairs had (exchanged one as thought it was a defect, turns out it's normal).
* Volume and ANC adjustments are sometimes hit or miss. Sometimes I have to rotate twice for the volume to adjust itself, and there is a lag. Definitely not as responsive as APM's dial. There is a technique- you have to do quick fast short motions and it helps for it to register.
* A big one for me... Noise/Hiss, not a completely silent noise floor - max Transparency with music is not usable due to the mosquito buzzing noise for me. Max ANC is much better but can still hear the 'mosquito' (again, both H95 pairs had this 'issue', so it seems the bluetooth module noise itself).
| Pros:
* Non-fatiguing sound signature with a more pronounced sub-bass adding an extra dimension to music
* iOS/Mac integration and seamless switching between phone calls and music
* Excellent/Superb build quality (better than H95! ... hurts to say this a bit) - see Cons for H95 for info
* Excellent control buttons - can feel&hear each click of the volume wheel, precise gradations, don't miss the touch controls especially if wearing gloves outside
* Easy one-button-click transition between ANC to Transparency or Off and to answer a phone call (H95
* Best ANC and Transparency from the ones I have tested/owned
* Quietest noise floor of any ANC Bluetooth headphone I tried. ANC hiss is very light and no bluetooth buzz. Transparency mode has no 'mosquito' buzzing.
* Can choose ANC/Transparency/Off for Phone Calls and VOIP calls - comes in very useful
* Better Mic quality for Phone calls and VOIP calls (did A/B testing with colleagues on the other line)
* Apple Care - pay the extra fee & use/enjoy/abuse them without worrying (incl. full replacement)
* Comfort - 8.5/10. Huge ear cups, ears don't sweat and don't touch the mesh, no pressure on scalp from headband, heavier weight isn't noticeable as distribution is good (reference is Denon 9200 as being 10/10 for me)
Cons:
* No ability to On/Off headphones, have to rely on Apple's always-on and hibernation-mode approach
* Already bought a 'proper' Case
* No way to use the headphones with 3.5mm passively (when no battery) - same issue with H95, but APM is even worse in this regard as it doesn't even allow a proper 3.5mm cable to be used...
At the end of the day... the APM turned out the better pair of headphones
for me (and I do not feel like I am 'compromising' on anything by choosing them).
I do not think that it would make sense for me to keep both, so the APM will stay, the H95 will go.
Hope my impressions help someone.
Cheers!
