phillkillv2
- Oct 29, 2013
I wish the blue was lighter and the pads were brown. Not bad though, just not what I expected. Mine should be coming this week or next week.
So, are the "improved pads" really any better?(anyone who owns the old M50's and got the X's) Looks like they could be a bit thicker in padding, but I'm more curious about how durable they feel. My M50's pads are just starting to crack in some areas, mostly where it's not in contact with my skin, but might be more stress(where it's cracked) if that makes sense. I'll admit I'm surely partly at fault for not taking the best care of them, but they're definitely durable for pleather(had them for about 2 years). Probably the biggest problem I have is the headband on my M50's as it's cracked a lot more(feels more thin), and unlike the ear pads it can't be replaced, though it could be modded with some sort of cover.
That cracked headband is a little worrying. Do you think you could take some pics of it? Do you think it's due to stress or sweating? Is it on the belly or top? Is it purely cosmetic or does it jeopardize the integrity of the headband structure?
Back to the earpads, does anyone know if the M50x earpads fit the M50? I imagine they would, which pretty much renders it as a factor for upgrading moot as one could hopefully just to buy them separately like the Beyerdynamic EDT 250s.
Where did you get them from? They look great
They are real:https://www.youtube.com/watch?v=y5DyEYuvF3o&feature=youtube_gdata_playerThey are actually fake. The uploader deleted everything and said that he faked it.
I didnt go with the M50x this time around, might buy them when they go cheaper on Black Friday. I just bought the old M50 with coiled cable, going to use them on the go most of the time. Cant wait to get them, got them cheap too for 112 bucks NEW
great price! good buy indeed, just hate the fixed cable though and coiled cable version is better than the straight (too much cable to wrap in a rubber band)
but coiled cable is heavy on one side too =( why didn't they make it shorter from the beginning!!! and add an extension cable inside, best of both worlds
but the new ones address that issue soo its all good!
