Vgrubb
- Oct 19, 2014
Thanks DACLadder. This helps a lot.
The he has a regnerative psu that is optimized for its application. I think it is worth the extra money. It's an amazing dac that can do it all.I've read through most of this thread and I'm considering an R7. Thank you to all contributors. I'm trying to understand the benefit of the HE over the non-HE. It seems it is USB related. Is there more? I'd planned to get a Singxer SU-6 if I get the R7. With the HE, is this needed or is USB input a better solution.
Regenerative on the usb? Are you sure?And to clarify the Amanero USB board that ships with almost all AGD DACs has recent power changes (6-9 months ago ?). Local power for the board changed to a regenerative type plus a linear regulator (class A). Also you can also purchase an option to upgrade the two Amanero board oscillators for lower jitter.
But as FredA mentioned above with his new R-7HE DAC he still prefers the Gustard U16 HDMI I2S.
Ok. That's what i tought.Absolutely not! LOL i thought I understood the Amanero USB isolator change but apparently runs on 3.3V. Here’s a good description of the new add-on board. Sorry for confusion...
https://www.audiophonics.fr/en/diy-interfaces/audio-gd-usb-isolator-for-amanero-p-12696.html
Well, there are few people that have heard both dacs. @remoss, if i am not mistaken, some people on french forums and the guy who reviewed the original r2r-7 for 6 Moon. If remember correctly, the guy in 6 Moon mentioned the r2r-7 was worth 1000$ more, which coincidently was the price of the Terminator at the time. In any case, it was pretty much even between the two at that time or the Terminator had a slight edge. Since then, the R7 has improved by 3 notches including the fw updates. It is fair to say the regeneration gives at least one notch, maybe two. With the change left buying the HE instead of the Terminator (6000usd), you can buy a M1 and 2/3 of a M3. So... . And you most likely have a better dac.Hello Guys,
Has anyone of you tried the R8, R7 or R7-HE against any similar priced Denafrips DAC?
Denafrips DACs have got rave reviews and opinions on Internet and I´ve just got curious!
I remember one French guy who owned the terminator, sold it and purchased the R2R7 - before all upgrades like DA7v2, firmwares nad AS38B clock upgrades.. Can't find his post but it should be in this thread.Well, there are few people that have heard both dacs. @remoss, if i am not mistaken, some people on french forums and the guy who reviewed the original r2r-7 for 6 Moon. If remember correctly, the guy in 6 Moon mentioned the r2r-7 was worth 1000$ more, which coincidently was the price of the Terminator at the time. In any case, it was pretty much even between the two at that time or the Terminator had a slight edge. Since then, the R7 has improved by 3 notches including the fw updates. It is fair to say the regeneration gives at least one notch, maybe two. With the change left buying the HE instead of the Terminator (6000usd), you can buy a M1 and 2/3 of a M3. So... . And you most likely have a better dac.
Well as long as the same is done on the receiving end, which has to be an acss input, i don't see any issue. Using xlr cables to carry acss will bring excellent results.I am thinking about pulling out the ACSS connections and replacing them with standard size XLRs. Or swapping the wiring from the ACSSs to the XLRs.
Doing so will allow me a lot more options for ACSS interconnects. Any issues with this?
Yep, I agree. I made a few pairs of ACSS cables. Not many wire options for the ACSSs especially if you want to use shielded wires. Also, a lot more options in XLR connectors.I don’t see any issue swapping ACSS to the regular XLRs. The mini-XLRs are a pain to solder plus you are limited to the thinnest wires to make them fit inside the connector housing.
