- Oct 14, 2013
You are correct, I did a major upgrade on the clock, and it will see even further upgrade on clock. But even with stock clock, the DSD was still superior on lks004 in comparison to r2r7. I did post about it previously.Also your lks now has a major clock upgrade. I insist cause the test i have done shown that the r7 was able to get a level of realism, smoothness and resolution playing dsd256 you will never be able to hear even playing 96/24 pcm.
I upgraded lks004 clock because it couldn’t scale up with Pinkfaun i2s in PCM the way r2r7 does
Regarding pcm and DSD in your situation, you need to compare it when you get a good source and source clock for pcm. You will observe what I do, the PCM done right is superior to DSD on the R2R7.
