FredA
- Dec 15, 2013
When I'm not using an int-amp I like to use Morrow's single ended MA1.2's in between amp&pre (18") -- the speed and transparency mimic's the integrated amp experience.
The cable between src&pre is where I focus on tone/color -- those cables are usually thicker and cost more
can you show us your parts list for this? 10+yrs ago I remember making a 6" ethernet cable to be a jumper between my stacked linksys routers and access point, and that link would fail intermittently. I googled some stuff about a minimum length (definitely longer than a foot) to achieve the correct impedance, and I think crimping 18" worked. I'd later learn that there's a min-length rule for USB as well, and people were reaching optimal results with 4.5' cables. That being said, I do have the 8" curious cable going into the W4S Recovery, so there's more to it.
I used a cat6a shielded wire from Monoprice. A header like these to avoid soldering on the F-1 (the f-1 comes with a male header, I soldered it on however).
https://www.ebay.ca/itm/20PCS-2X10-...ield-/351494232951?hash=item51d6b05b77&_uhb=1[
And a cord grip like these:
https://www.ebay.ca/itm/2pcs-M8-Wat...-5-7mm-Wire-/321715241257?hash=item4ae7b90129
I soldered the rj45 to the male part of the header, a the bottom, then trimmed the pins so that all fit in my case. I suppose there is enough room in the case that now is available from singxer. I had to remove the jacket and shielding for the wire for it to pass through the grip's hole. The grip being metallic, no shielding issue there, assuming it matters in the first place.
