Herbal
- Apr 19, 2007
I advocate building a PC since that's what I know and love.
Here in the UK you can piece together a low spec (1.8GHz, integrated graphics, gigabit network, 1Gb RAM) for around $300 which comes with basic SATA RAID integrated into the motherboard (simple RAID such as striping and mirroring). Add to this whatever case takes your fancy and the amount of storage you need and you can build something that does what a NAS box does for a lot less with better future upgradability.
As I mentioned in my previous post, a Lian Li case could takes 10 drives as standard and could accept another 10 with use of drive bay mountings.
With a PC solution you've got everything covered. You can do whatever you want with a PC box but a NAS box is just that...a pretty simple box (unless you like voiding warranties and hack the heck outta it
I guess we should mention the downside of PC's in that in order to get a whisper quiet system you need to spend the cash and put the time and effort into it and they do ultimately use more electricity than a NAS box (although choose the right parts and it's pretty insignificant).
I suppose it's a question of how savvy you feel you are with a PC and customising it to what you want and need.
/EDIT - Just a quick note that RAID 5 can be performed on 3 drives although some NAS boxes may require 4 for some unknown reason.
