need urgent help
post-149843
Thread Starter
Post #1 of 11
nae45ro
Hy guys! Do u think u can reccomend me some good headphones for around 200$?
post-149850
Post #2 of 11
Ken
welcome to Head-Fi
there are thousands of views on different headphones.
use the search and you will be reading for days
good luck
all the answers are here.
post-150006
Post #3 of 11
bifcake
Hi,
I like the Sennheiser HD-580. They go for around $140 on E-bay and there's no difference between them and the HD-600's that go for about $225 on E-bay.
In order to get the most out of them, you'll need an amp. I got Creek OBH-11 for $150, with which I'm very happy. If you don't want to invest in an amp, you may want to consider Sennheiser HD-590's. They're nice and don't need an amp, but they're not quite as well balanced and natural sounding as the 580/600's.
post-150008
Post #4 of 11
dohminator
Any of the audio technica cans are good choices. You can find them here www.audiocubes.com They don't need an amp to reach their full potential either
post-150023
Post #5 of 11
Flasken
Exhibit A in the case FOR a legal drinking age.
Jesus christ man, he's a newbie, don't lie about stuff he doesn't know about, he'll believe you!!
OF COURSE most of the AT cans need an amp to get to their full potential...
My recommendation is that you do a search on these phones:
HD580
Grado sr60,80 and 125 (dunno if the 325 is within your range)
Beyer 250-80, 770, 531
The grados are hard to obtain at a reasonable price in europe. The other phones can be ordered from the most noble of all online dealers, www.meier-audio.com
post-150031
Post #6 of 11
Eagle_Driver
HD580
The headphones that you're recommending also NEED an amp to get to their full potential, too! Though most can be driven directly from a *gutless* portable, the resulting sound quality is NOT what I would consider even "mid-fi", let alone "hi-fi" (though I'm sure that the sound would still be WAY better than with the 'phones that come packaged with such portables). In fact, the ONLY headphones that sound at their full potential without an amp are the cheap crappophones from various brands (bundled with portables or sold separately) - when amped, those either show NO improvement from their already crappy sound OR actually sound EVEN WORSE.
post-150049
Post #7 of 11
nae45ro
thanks for the help guys.I think i'll go with the 580's but i want to use them exclusively with my line in home,wich also has an amplifier.Give me some clues!Do i still need an amplifier?
post-150059
Post #8 of 11
Audio-Me
You don't need a dedicated headphone amplifier, but you definately should if you want to get the most value out of your money. I recommend a diy design amp called the META42, they can be had for cheap.
post-150084
Post #9 of 11
fredpb
Depends on how much quality you want in your audio.
HD580/600's for best performance need a proper amp and optional cable. Add $100 for the cable and +$350 for amp.
The Musical Fidelity Xcans are $280 (tube amp).
Just plugged into a receiver, well, they are not at their best. A cheaper headphone in this case can perform better overall.
post-150127
Post #10 of 11
bifcake
You don't NEED an amp to drive the 580s with your receiver. However, an amp will definitely improve things. A good amp will let the 580's blossom. You may still like the way the 580s sound with a receiver, but the difference with the headphone amp will be a more enveloping, dynamic and spaceous sound. If you can afford it, get an amp. You don't have to get an expensive one. Creek OBH-11 or the Musical Fidelity X-Can v2 are very good.
Re: cables, I did an A/B comparison with stock cables and replacement cables and I couldn't hear any difference. To me, the extra $100 for the replacement cables is an absolute ripoff.
post-150140
Post #11 of 11
dougli
A headphone that gives decent sound without an amp is the Ultrasone HFI-600. $105 USD at Meier Audio, higher elsewhere. There's at least one review floating around the Head-Fi forums.
