Dorito123
Banned
- Jan 22, 2008
Why would you need anything besides the Disk manager in windows? I think if you stay away from 3rd party software you will be ok. I'm not sure about your lost data because I can sit down in front of your computer but next time use windows disk management. You can use it to remove and add partitions and resize partitions. And it wont screw up. Good Luck! and I hope you can fix it!
