DaBomb77766
- Apr 14, 2011
There are non-expensive choices other than mono-price.
Maybe, but monoprice has a pretty good reputation for making cables that work. All you need is for the cable to work, you don't need fancy materials and crazy nylon sleeves for it to sound good. It's not like the purity of the cable will make the light slow down enough for us to hear the difference. Also, I doubt you'll find anywhere that sells cables as ridiculously cheap as monoprice.
