ambush276
- May 12, 2010
i just bought a new laptop and i obviously do not want it to decode my sound with its crappy sound card..
i have a LiteAM dac.. but i need something that goes from USB (plug into the laptop) to an optical out to plug into the dac. I want something that will not touch the signal and allow for the dac to fully decode the signal and send it to the amp.. If i get something that uses optical is that the case???
i was looking at these two..
will these make work without touching the signal?
is one better than the other?
i am ONLY pluggn' it into the dac.. ??thanks!
http://www.newegg.com/Product/Product.aspx?Item=N82E16829270009
http://www.newegg.com/Product/Product.aspx?Item=N82E16829186002
