Need some recommendations on sound card op amps for Xonar DS
post-7647968
Thread Starter
Post #1 of 3
Kolya Medz
I recently bought an Asus Xonar DS sound card
http://www.amazon.com/ASUS-Xonar-Channels-Interface-Sound/dp/B002VAD716
and was wondering what a good op amp upgrade would be.
I use a pair of modded JVC HARX900 headphones
http://www.amazon.com/JVC-HARX900-High-Grade-Full-Size-Headphone/dp/B0013P3ZOE
(these are great for only 60$)
I listen to everything.  from baroque to trance..
I also do a lot of gaming and movie watching.
What is a decent all around op amp(s) that would be a good upgrade from stock?
Or will I not notice a difference between stock and an upgrade?
Or are these amps meant to boost specific things (some bass heavy, some with better mids... ect..)?
--Thanks
post-7648765
Post #2 of 3
genclaymore
MI
MI
Age
37
The best thing to do is roll op-amps and find one you like. You can try some LME49720NA,OPA2111KP,OPA2107AP. Also the most important thing is, when your installing op-amps you must make sure the notch on the socket match the notch or circle thats on the op-amp. both should be pointing the same direction.
putting it in the wrong way is something you do not want to do.
post-7651296
Post #3 of 3
Mad Max
USA
USA
Also add TLE2081A, HA3-2525, and OPA602B to that list.
