The HFI-780 does not have a removable cable IIRC.
General Headphone recabling:
You would need to decide dual or single entry.
Get some black heat shrink, solder, solder wick, flux, and a multimeter.
Personally, I like adhesive backed heat shrink to use as the first layer.
Open up the headphones by taking off the pads and unscrewing it. See the back of the driver where the two wires go?
Now "buzz" the cable to find out which piece corresponds to which channel on the plug. Mark this down somewhere or use a dry erase marker and mark the spot where the signal goes to, leaving ground blank. Marke the distance between the end of the wire and the entry. Now add on .25inches to that. Use this to give you the distance at which to start making the strain relief with the heat shrink. Pull the cable through the hole, all the way up to the strain relief. Then, secure the inside with a zip-tie or heat shrink ( I like adhesive heat shrink). Now solder the wires to the correct places on teh back of the driver. Test and then put everything back together.
You should always make the cable first FYI and then put it on. More consistant this way.
If you want Dual entry, get a power drill or dremel and make the hole yourself the same size and location as the other one.
Cheers and Best of Luck!
