003
- Oct 4, 2005
All right, pics would be great! If I can't find any easy way of getting the adapter to stay on the case, I might just break out the good old epoxy.
Originally Posted by Nugget /img/forum/go_quote.gif Silent PC Review's fan recommendations are definitely worth a look. One more thing to consider: A major source of fan noise is not the fan itself but turbulence and air pressure, both of which are increased by having little room between the fan blades and the components being cooled. Take a running fan and hold your hand six inches from it; then hold your hand half an inch away, and there'll be a very noticeable noise increase. This is probably a good part of your problem. That PP&C unit is built like a rock, but as a consequence it's also crowded inside. You might try a shroud of sorts that ducts air to the PSU's heatsinks and provides an inch or two of clearance between the fan and the interior components. |
[left]Name Code Qty Each Options -------------------------------------------------------------------------- Nexus 80mm Real Silent 840556054054 1 11.95 Fan Grill = None Case Fan SP802512L-03 Fan Screws = None Subtotal 11.95 Shipping 5.80 Total 17.75 Name Code Qty Each Options ----------------------------------------------------------------------------------- Sanyo Denki San Ace 80x15 109P0812M701 1 18.95 mm Scythe SFF21E 49 CFM SFF21E 2 14.95 Add Black Sleeving = No S-FLEX 120mm Quiet FAN by Sony Set of 4 Rubber Fan 4rubber1 8 1.00 Rivets 80mm Fan Filter FGP-80 1 2.95 92mm Fan Filter FGP-92 1 2.95 120mm Jumbo Fan Filter FGP-120 1 2.95 Subtotal 65.70 Shipping 4.60 Tax 0.00 Total 70.30 Name Code Qty Each Options ------------------------------------------------------------------- SVC 80mm to 120mm UV Blue FA8012-UVBLU 1 5.99 Fan Adapter Subtotal 5.99 Shipping 4.55 Total 10.54[/left]
