Need More Website Design Help hehe
post-207817
Thread Starter
Post #1 of 6
NotoriousBIG_PJ
Step 1: Plug power cable into wall. Step 2: Plug other end of power cable into....umm.... Step 0.5: Order something to power with power cable.
If I want to have the same side menu for multiple pages, can I save it as a .obj and then just link to it from those multiple pages? I did this with .asp at my last job so is it cool to do it with regular html files?
Thanks,
Biggie.
post-207846
Post #2 of 6
royboy2k
Here's what I did for my first website using Dreamweaver. I just created one vertical frame on the far left for navigation, then used the rest of the space as my "main" frame. Both of these frames are .htm files. The "navigation" frame never changes once it's loaded up, it simply contains links which are opened up in the "main" frame.
I dunno if that helped or if you already knew all that. Basically I'm saying just use frames, but maybe you're doing something different.
Good luck.
post-207900
Post #3 of 6
NotoriousBIG_PJ
What I'm talking about is something different. If I use frames, will there be a black line seperating the two files?
Biggie.
edit: server side include is what i'm talking about. i think it will work hehe..
post-207938
Post #4 of 6
leon
I don't know anything about .asp or .obj, but in terms of HTML code it's definitely possible to eliminate the "borders" of your frameset.
post-208055
Post #5 of 6
royboy2k
Yeah you don't have to separate frames with a line.
post-208067
Post #6 of 6
elipsis
No, he's talking about something totally different to frames. Yes, you can use SSI's here.
