hedmaster
- May 5, 2009
Hi guys, I am at a loss as to what my best option for a DAC is at this point.
My budget is about $300.
My goal, to get the best bang for the buck.
My current rig:
DIY computer w/ Auzentech X-Plosion sound card
Features and Specifications
Shure SRH 840, Senn PXC 350, REO 2, PX 200, PX 100
Let's start with the sound card. From the specs, I don't know if I would be better off just running the mini plug out to the rca input on my amp.
I can roll the opamps, including: 627au, 637au, 8620BR, 627sm, 637sm, 797ar.
These are the opamps listed on their site. But, they also talk about adapters.
Don't know if I would need one or not, but it seems to be necessary from their description on their web page. Auzentech, Inc. Sound Cards. Audio You Can Believe In. World First soundcards for Music, HTPC, and Gaming.
I have already tried running a mini plug to rca to my EF2, nothing happens. I don't know if I am missing something here, or if anyone can give me any pointers, or what to look for?
Well, then let's look at external DAC options.
Don't need portable, but portable is ok, if that fits the bill.
Would it be a good idea to run out of the optical on the back of my soundcard to a DAC?
I have been looking at the ibasso D10-small, option of opamp rolling.
or the pico DAC/amp combo-stretching it at $400, but I could do it.
or the Compass for that price. Not too thrilled with the Zero-don't want to wonder if it will fire up every day
So, this is where I am. I have been pouring over these threads for months now. Which is the reason I have the Shures, and the EF2 now.
As you can tell, I am at the beginning of my audiophile journey, so any improvement will be just that for me-an improvement.
Thanks for your help, guys,
Matt
My current rig:
- C-Media CMI8770 PCI chipset (8CH audio single chip with DTS® Connect and Dolby® Digital Live Real-Time Content Encoder)
- 8CH codec embedded PCI audio single chip
- Full-duplex 8CH 24bit/96kHz DAC / 2CH 16bit/48kHz ADC
- Integrated S/PDIF output supports 44.1kHz/48kHz/96kHz sample rate in XP at 16/24 bit resolution
- Integrated S/PDIF output supports 44.1kHz/48kHz sample rate in VIsta at 16 bit resolution
- The world's first DTS¨ Connect logo program certificated PCI audio board
- DTS® Interactive : A real-time 5.1 encoder that takes any 2 or more channel and encodes it into DTS® bit stream. DTS® Interactive provides a single cable connection via S/PDIF digital audio output to a DTS® enabled surround sound system by encoding all audio into a DTS® compatible bit stream at 1.5Mbps
- DTS® NeoC : An up mixing matrix technology that turns any 2 channel audio into 7.1 surround sound. DTS® NeoC, based upon DTS® Neo:6 matrix surround technology, transforms any stereo content such as MP3, WMA or CD audio, into a 7.1-channel surround sound experience
- Dolby® Digital Live(DDL) Real-Time Content Encoder converts PC audio into a 5.1 channel Dolby® Digital bit stream
- Swappable dual DIP type OPAMP controlled preamp circuit (4pcs output control OPAMP IC with DIY socket, 2pcs MIC input control OPAMP IC with DIY socket)
- Max 2.8Vrms full swing analog output gain by unique preamp circuit / incredible powerful analog output, improve dynamic range / SNR
- Proper OPAMP control circuit (+8V, -8V dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level
- Package contents: Auzen X-Plosion 7.1 Audio Card / MPC to MPC(2pin-2pin) CD S/PDIF audio cable / TOSLINK fiber optic digital cable / installation CD / warranty card / owner's manual
- Swappable OPAMPs: All Auzen soundcards support swappable OPAMP sockets for OPAMP upgrades.
Matt
