Me x3
Member of the Trade: FiiO Store Argentina
- Nov 22, 2012
Reading frequency response graphs is not as simple as it looks. The vertical axis, despite being fixed on the graph is variable in real life, and thus that should be taken into consideration.
To start you should not isolate bass, midrange and treble. For instance, as you can see DT880 has more bass than HD448 on that comparative plot, but also has much more treble and that affects the whole perception of the tonal balance of the headphone.
If you want something that's DT880-like but just a tad less bright/sharp, you can check the AKG K702.
Keep in mind K702 is similar to DT880 in the big scheme of things (neutralish/very controlled bass and present yet slightly softer treble)
For the sake of simplicity K712 is a fuller sounding K702. So, you get present yet slightly softer treble than DT880 and just a tad more bass presence.
I would skip HD600 and HD650 based on your descriptions since these are somehow warmer and softer than HD598.
