tumtuter
- Jul 2, 2014
I personally don't use the wire you have circled there, the shield. I normally use the clear for the left ground, blue for left signal, black for right ground, and red for right signal.
Is this correct that at the ends of the 3 pin XLR does not need a ground. Just hot and cold right?
L- Clear
L+ Blue
R- Black
R+ Red
Also what should I do with the 'shield' cut it off or twist it around the cable? Thank you. Sorry for all these questions. This is my first time doing cable work.
Alright, this is what I was talking about when I was describing how to remove the stock 3-pin mini XLR. I just happened to have a KXX here so I better show you how while I have the opportunity.
I understand that know. I feel like a idiot, was pushing it the otherside. Well at least the connector is out anyway with the other method.Stock connector.
Heat with a hair dryer or heat gun, I used a hair dryer. Don't just heat it at this angle, this was the only way I could take a picture and show the hair dryer. It wasn't even on tbh.
After the area is hot, get a good grip on the part and push the stock connector out from this direction.
It should slide right out if the area was warm enough. ABS plastic won't begin to melt until a little over 250 degrees F, so don't be too afraid if you're heating it with a hair dryer. The longest I would apply heat with a hair dryer on HIGH would be about 20 seconds.
The 4-pin mini XLR chassis mount connector is the same size and shape as the stock connector.
You'll have to glue the new connector to secure it after soldering the wires to the connector.
