TripBitShooter
- Mar 24, 2014
i was the one who said they were not worth it, as in my country they are too close to in price to an M50x to be worth it
No the Evos are still in production, if anything because now they are offering an Extra Item (velour Pads -which are awesome) the store might of confused a modification for a end of manufacturing.
they guy talking about the "SRH440" just saying they're fine. though better options near price range. depends on preferences.
I really think you should throw in that extra money and get the E12, thing is a beast, and will power most things you throw at it. It can supply >880 mW @ 32 Ohms. (That is a LOT of power for such a small portable device. Though I have noticed it gets hot depending on the variance of impedance of the headphones.)
I noticed your now looking up to $300? I assume that's somewhere you can go but prefer not to go to.
If your looking at the M50x, Gotta look at the PRO700MK2s too, similar price on amazon.
But be warned now. they have some SERIOUS clamping power. I like the high clamp personally, but I can almost say you will hate the clamping.
Not to mention that the stock pads are utter crap. If you do get these, I can always send a link of the ear pads i got to replace the stock pads. (gel pads are Divine)
Take my word for it, They are Awesome, I preferred them over the M50s, I'm pretty sure the M50x is not big enough of a change to take my consideration. (One more thing, upper bass hump... easy fix with 4 XL cotton balls stuck in each ear cup.)
Oh do take in consideration that they have an INSANE Max input power... of 3.5 Watts... that's 3,500 mWs That's ridiculous, but hey, plenty of power to let you pick out more detail, and have some SERIOUSLY solid sound. AKA High power amps will make the sound clearer. (use with FiiO E12 Bro, freaking makes me wanna sit and enjoy the music.)
Pro700MK2s definitely not going to be great out of the box, but worth considering.
might wanna look Into Grado too. Yeah, they open... but if you like good treble, they are to be considered.
OH if you don't mind spending the Whole $300, get FiiO's new X1 Music Player + A Micro SD card to use it, and a SoundMagic's HP150.
(as ya'll notice im not considering the pricing of shipping, or the Micro SD card. With the Micro SD card, start cheap and small, just to get you going.)
Actually, Might wanna get the FiiO X1 And a BIG Micro SD, that'll put you ~$150. Then you can Consider a Cheaper headphone but get a great source. (A superlux headphone would do nicely.) That'll give you time with a great source, so you can focus more on a great headphone in the future. No need to look at an Amp with the X1 as It'll have the juice to get you going.(<-sorta) And worry more about the headphone itself.
I agree with others regarding M50s. There is also even cheaper option - Creative Aurvana Live and new model (I've just received mine yesterday and they are blast!) Aurvana Live 2. Prices are : AUS$79.00 and AUS$99.00 plus shipping respectively and you can't go wrong with either of them. They are seriously unbeliveble value for money.
