KillTheNoize
- Jan 28, 2012
Both are about the same price on amazon currently..
Any opinions on which I should choose? I plan on buying new IEMs within the week. I currently only have MEElectronics M6s and I like them, but have a feeling I might be wow'd by an upgrade..Since I use my iems quite often, I figured it would be worth spending a bit of money on to last until I can afford customs.
I listen to primarily deep dubstep with lots of sub bass, along with other electronic genres and hip hop. I really like the shape/build of the M6's, and the shures are similar, so I think I would like the fit but Im not sure of the sound. They also have a removable cable. Although, I have heard quite a bit of positive talk about the atrios, so Im just unsure.
Any input is highly appreciated, if you would suggest another iem around the same price (150-160) let me know
