need help choosing dac for maudio bx5...for good sound quality
May 19, 2015 at 1:31 PM Thread Starter Post #1 of 3
Enkaydian
Hey guys. Im looking to get a dac for my maudio bx5 d2. Im looking to spend 150 or less. I want good sound quality. I had an alesis io2 that went out. Im looking for a step up. I do not plan to record. Just listen. Music and games and movies. Im looking at the focusrite scarlet 2i2 . but im also looking at the schiit modi2. but it has no volume control and i heard that the connections will have some feedback if i did use modi due to being unbalanced sorry im not to familiar with these things. I want to know howni can get a volume control if i went that route. Also other options for good sound quality.
May 19, 2015 at 1:56 PM Post #2 of 3
PurpleAngel
California
Hifimediy USB DAC, $57+ shipping ($8?)
http://hifimediy.com/U2-DAC
I'm guessing this USB DAC comes with a better DAC chip, then the 2i2
Hosa CMP-153 cable ($3.79) to connect the USB DAC to the BX5
http://www.sweetwater.com/store/detail/CMP153
This setup will use an un-balanced connection.
May 21, 2015 at 1:22 PM Post #3 of 3
cel4145
grand rapids, mi
A Modi would work fine since the BX5 does accept unbalanced inputs, although definitely doesn't take care of your volume control issue. Then you'd have to add a device on with that. For the money, the Audioengine D1 would give you the pre-outs on the back to connect your speakers and control their volume, as well as a headphone jack.
