domsch1988
- Sep 3, 2013
Hi, It just came to my attention, that the HM5 replacement Pads should fit my DT770 Pro's. If that's correct, i might save on buying new headphones.
So can anyone confirm that the HM5 Memory Foam replacement Pads in leather and velours do actually fit the 770? Also, how do they compare thickness wise with the stock grey velours pads?
I'm not to concerned about the change in sound.
Edit: Also, if they fit, do you prefer velours or pleather for comfort? Are they different in thickness?
