Lol no way. LCD 3 and Ether Flow are leagues ahead of NighthawkSo you think the Nighthawk can keep up or surpass the lcd 3 and the Focal Elear, Ether Flow?
Need a suggestion. Miss being blown away by my setups.
- Thread starter chef8489
chef8489
- Jul 1, 2005
You think they will surpass my es60? Thats a pretty tall order. Some dont think a custom iem has much over full sized cans, but I would have to disagree from experience. The es60 are pretty amazing iems and thus lies part of the problem and why I am looking at 2k headphones.it will surpass the headphones that you have now, thats for sure
FastAndClean
Previously known as presata
did you try them with those velour padsLol no way. LCD 3 and Ether Flow are leagues ahead of Nighthawk
Pads only do so much. You can't improve resolution with pads. Pads change tonal balance somewhatdid you try them with those velour pads
FastAndClean
let me be more specific here, the nighthawks sound completely different with those velour pads that i mention than stock pads
FastAndClean
yes you can, the headphone can have amazing resolution clouded by unnatural tonal balancePads only do so much. You can't improve resolution with pads. Pads change tonal balance somewhat
Sure but no matter what you change, nighthawks can never surpass a pair of LCD 3 when both are amped properly.let me be more specific here, the nighthawks sound completely different with those velour pads that i mention than stock pads
You might like the sound signature of the nighthawks but LCD 3 is objectively the superior HPs
FastAndClean
if you fix the balance the clouds will be gone and you will be able to see deeper into the sound picture
Have you heard a pair of 2016 LCD 3 properly amped?if you fix the balance the clouds will be gone and you will be able to see deeper into the sound picture
FastAndClean
superior in weight yes the sound is objective, for you it can be better, for Johny notSure but no matter what you change, nighthawks can never surpass a pair of LCD 3 when both are amped properly.
FastAndClean
yes with MOON NEO 430 HAHave you heard a pair of 2016 LCD 3 properly amped?
There are objective aspects to sound too like soundstage, resolution, definition. Even if you don't like the sound signature of the LCD 3 doesn't change the fact it is superior to the Nighawks objectivelysuperior in weight yes the sound is objective, for you it can be better, for Johny not
Johny probably doesn't know what to listen to when objectively comparing headphonessuperior in weight yes the sound is objective, for you it can be better, for Johny not
FastAndClean
no Johny probably have different taste than you, can you believe that, seems impossible i knowno johnny probably have different taste than youprobably doesn't know what to listen to when objectively comparing headphones
Johny does not know the definition of objective and is clueless that objective has nothing to do with taste. I know Johny is really thiccno Johny probably have different taste than you, can you believe that, seems impossible i know
