Maxvla
- Dec 26, 2002
It will.
Will the statement amp has a 4 pin balance XLR output?
It will.
The only thing that bothers me are the hard-to-reach power on switches. If they will be positioned the same as Asgard between the power cable and input it will be hard to reach the lower unit if you have both the amp and dac. I think it would be much better if the power button is either on the far right or far left if not on the front panel.
It does. The boards are PCBs. Currently the boards have the switch on the read. Would mean redirecting the traces to the front and having them re-printed, re-milling the cases and dumping the ultitarian switch for a pretty one. Not hard in the brain teaser sense, but financially unfeasible. That sort of thing needs to be asked for while the design is still on paper.
