Sennheiser,
In the spirit of this topic, I would like to know how an average audiophile listening to over-the-ear headphones can accurately gauge the decibel level they are hearing?
I have a 'RadioShack' sound pressure level (spl) meter*. I take the headphone off of my head while its playing music and I place the microphone portion of the spl meter directly into the earcup so it rests on the portion of the driver that faces my ear. Hopefully, this is a conservative approach that will, if anything, yield a decibel level higher than what is actually hitting my ear? Of course, sound could amplify in the pads when the headphone is actually over the ear and I cannot say that the driver outputs the same level of sound consistently across all portions of the driver. And then there is the concept of ear gain (which i assume is irrelevant to this conversation)? and the driver vibration against the mic may add extraneous noise (so sometimes i hold the mic very slightly above the driver so it isn't actually touching) but i am not sure if that is significant ...so I don't really know that my approach of resting the meter on the driver is a reasonably accurate/acceptable way to measure?
When it is stated that 80db is safe for x hours of listening what techniques and technology is best to determine that decibel level?
1. is it adequate to do the procedure I described above?
2. is there a particular spl meter or style of meter that is more accurate?
3. is there anything similar to an iem that can be placed into the ear to measure spl in decibels and then send via bluetooth (in real-time) the measurement to a phone app all while listening to an over the ear headphone?
4, what are the appropriate (weighting and response) settings to use when measuring the spl to determine whether we are listening safely?
Obviously a measurement rig would probably be the most accurate way to measure, but they are expensive ...unless a cheap one exists for the simple purpose of measuring overall SPL with a lower degree of accuracy than is needed by a pro trying to map out frequency response?
These are questions that would be helpful to have answered.
*generic image of radio shack spl meter - this unit has the mic slightly inset from the outter edge of the casing so when i place the mic onto the driver the mic is technically not directly touching, but it is very close. i would think this works better than the spl meters that have a mic with a spherical foam wind guard as there would be less extraneous noise introduced and the meter can rest perfectly flat and still against the driver.
