Did your headphones ever arrive? What are your impressions of them?
Yep they did! Just turned up yesterday. Will post initial impressions and some pics tomorrow or so. Thanks for following up.
Looking forward to your opinion on the technical performance in the treble.Yep they did! Just turned up yesterday. Will post initial impressions and some pics tomorrow or so. Thanks for following up.
How would you go about buying them from China in the US? I didn’t see them on AliExpress.Picture of my set (using for a month): https://www.reddit.com/user/Impossi...7vem/470_nan6_planar_headphone_made_in_china/
The headphones sell for $470 in China. One thing I can guarantee is that the headphones are definitely worth the price, with few drawbacks other than the soundstage which is not that big. There is nothing wrong with the tuning, and the sound texture can be as good as he6. It is like a child of sundara and he6 with the trend of sundara but soundstage and quality of he6. The overall design of the speaker is based on he6 but using diaphragm similar to sundara's and some other little adjustments are applied. You will need powerful amplifier to drive this headphone, since driving is as hard as HE6 and HE6se.
I am now in China haha. Nan 6 is not sold on AliExpress because it unavoidably used some tech from Hifiman and may cause patent disputes. Thus, It is sold directly by the manufacturer on a second-hand trading platform in China called "Xianyu". I don't know how foreigner can buy this, but I can promise that your he6 is already good enough, nan 6 won't be better but only cost less money. You can enjoy your he6 Btw, the cups' size is as same as he6.How would you go about buying them from China in the US? I didn’t see them on AliExpress.
Are the cups/pads larger than the HE6? I love my HE6se other than the cups and pads are maybe 15% smaller in diameter than I’d like.
I find that hilarious given how many counterfeit watches are happily sold on AliExpress, and after HiFiMAN's R-10P/D stunt.Nan 6 is not sold on AliExpress because it unavoidably used some tech from Hifiman and may cause patent disputes
What I can say is that this manufacturer developed most of his technologies on his own, but it inevitably overlapped with some of the technologies from large companies. I am familiar with him and I know that his production process is different from Hifiman and even achieves better quality control. The texture of the diaphragm circuit under bright light is totally diferent from he6's. Only circuit shape is copied from he6, but the spacing of the magnet, the distance from the diaphragm, the stress in the diaphragm and the thickness of the diaphragm are all different from hifiman's. That's why it looks like he6 but has the curve of susvara, but sounds totally diferent with susvara.I find that hilarious given how many counterfeit watches are happily sold on AliExpress, and after HiFiMAN's R-10P/D stunt.
what amp u use?Alright guys here they are. First impressions are very positive.
Comparing to the HE6SE V2, to me the NAN6 sounds slightly fuller in the mids, with a more linear and tamed treble than both the HE6SE V2 and HE1000 V2. The graphs are right - the susvara has a smooth treble and so is the NAN6. I really like vocals on the NAN6, they have body and is pleasantly authentic. Due to the short amount of time I've had on them I can't speak with certainty on the technicalities, but I can feel that they are very capable as well, certainly on the level to trade blows with the HE6SE V2. One of the highlight among first listening was macrodynamics - how dynamic and punchy the NAN-6 is. This may have to do with how the driver diaphragm of NAN6 is specially tuned as @wstgr mentioned above. I will need more time before in depth comparisons though. All in all very impressed by them.
note: this is only some quick first impressions without serious comparisons, and the opinion from one guy.
what amp u use?
So you saying a30pro is driving full for nan6??I have a custom solid state amp that delivers 5.5 watts into 50 ohms, but I mainly evaluated the NAN6 with the Topping A30pro, on which I use mid gain and around 10am for 70-75db averag listening level. In fact with 3.4 watts into 50 ohms the A30pro is already powerful enough to provide ample current and swing for the HE6SE or NAN6 to get sufficiently loud for my listening volume.
On top of amp pairing, IMHO what’s more important are pad choice and the included velcro mod. My first impressions were with the default hybrid pads and without the velcro tape mod. By intentionally introducing a mild air gap the velcro mod adds pressure release conditions to the NAN6 and would therefore change how they sound. Basically there'd be more mid-bass and treble extension in the air regions, the latter which may cause slight harshness/sharpness. Although I shoud note that perception of treble extension varies a lot person to person and to age.
For the wiggle lovers, I will upload some measurements of my unit later. But the TL;DR is they measure basically the same as the pair Crinacle got.
You saying some sharpness due to the air gap of the earpad?I have a custom solid state amp that delivers 8 watts into 50 ohms, but I mainly evaluated the NAN6 with the Topping A30pro, on which I use mid gain and around 10am for 70-75db averag listening level. In fact with 3.4 watts into 50 ohms the A30pro is already powerful enough to provide ample current and swing for the HE6SE or NAN6 to get sufficiently loud for my listening volume.
